mechanical fan vs electric
#2246501
02/03/17 02:06 PM
02/03/17 02:06 PM
Posts: 8,043 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Thought I would start another post about cooling a 500+ BB in an A body. Still not sure which way I'm going with the radiator,but as this point I could go A or B body down flow. I would like to cool this with a 440 source mechanical 40gal water pump and a flexi-lite 6 blade fan with a full rad. shroud. Can this be done or do you think it would be easier to cool with electric fans? Heres the fan.
Re: mechanical fan vs electric
[Re: mopar dave]
#2246532
02/03/17 02:38 PM
02/03/17 02:38 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Mechanical fan on a clutch or electric. Never a direct drive fan.
Mechanical can move a lot more air, but the advantage of electric is you can cool the radiator while the engine is off. If you are over heated, kill the motor, let the fan run a minute, then fire it back up to circulate water, and repeat till you're cool.
I like electric because it's only on when you need it. Not turning the clutch/fan when you don't need it. I kept a 500 hp big block cool with a properly sized fan and clean, well maintained radiator
**Photobucket sucks**
[Re: mopar dave]
#2246615
02/03/17 04:44 PM
02/03/17 04:44 PM
Thumperdart
State of confusion
Thought I would start another post about cooling a 500+ BB in an A body. Still not sure which way I'm going with the radiator,but as this point I could go A or B body down flow. I would like to cool this with a 440 source mechanical 40gal water pump and a flexi-lite 6 blade fan with a full rad. shroud. Can this be done or do you think it would be easier to cool with electric fans? Heres the fan. El decapitate..........those things are dangerous and I run the HHR chevy fan w/a Moroso w/p. and they work well together and the new pump cools a bit better. Street car, desert heat.............
[Re: 70Cuda383]
#2246653
02/03/17 05:43 PM
02/03/17 05:43 PM
Posts: 5,080 organ
maximum entropy
organ
never say never.
[Re: maximum entropy]
#2246656
02/03/17 05:46 PM
02/03/17 05:46 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
never say never. Yep. I ditched the clutch in favor of direct. Best way to move air if that's your goal.
[Re: mopar dave]
#2246661
02/03/17 05:52 PM
02/03/17 05:52 PM
Posts: 13,387 Marion, South Carolina [><]
an8sec70cuda
Those flex fans are notorious for losing blades and hurting people. Get a good electric fan setup. I use the fan and shroud setup off a 2003 dodge Viper.
[Re: mopar dave]
#2246663
02/03/17 05:54 PM
02/03/17 05:54 PM
Posts: 7,506 Az
Crizila
Az
Thought I would start another post about cooling a 500+ BB in an A body. Still not sure which way I'm going with the radiator,but as this point I could go A or B body down flow. I would like to cool this with a 440 source mechanical 40gal water pump and a flexi-lite 6 blade fan with a full rad. shroud. Can this be done or do you think it would be easier to cool with electric fans? Heres the fan. What you propose would be the way I would go, ( Simplest, least costly, best cooling capability, no additional amp draw issues to contend with ) especially for the street. I would lean more to electric for race only application.
Fastest 300
[Re: Crizila]
#2246673
02/03/17 06:06 PM
02/03/17 06:06 PM
Posts: 516 ,Pa.
68dodge
,Pa.
I like the electric fans and pump, for street or strip in my big block A-Body. On the street, if you would run into a problem with the car running hot because of traffic on a hot day. You can just stop and let it cool down. Same when you at the track between runs. But that's your own choice.
[Re: mopar dave]
#2246693
02/03/17 06:24 PM
02/03/17 06:24 PM
Posts: 4,457 Washington
madscientist
Washington
Then fan you posted is the fan I use.
I can tell you that a quality mechanical pump and fan with the correct pullies (I overdrive my WP 6% and would have done 10 I'd I could have found pullies).
I have a hard time getting heat in the engine without a Tstat.
The WP, speed you turn it and the area of the radiator is what counts. Most guys don't run enough pump or pump speed. Flow is what cools. The fan pulls air at idle and low speeds.
