Re: Anyone retro fit an electric in tank fuel pump?
[Re: GLR]
#2379451
09/30/17 06:40 PM
09/30/17 06:40 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I also did the TanksInc set up, mine still has a carb, with a return system, EFI in the plans. hot fuel has not been a issue, & I drive this car, AC & temps over 100 deg in Southeast Texas.
[Re: Supercuda]
#2379454
09/30/17 06:48 PM
09/30/17 06:48 PM
Challenger 1
Cincinnati, Ohio
You have any sump or baffling in there to prevent the pump from sucking air?
Yes there is a sump that comes with that pump. Very nice job there Andy. How did you handle the final finish? What is that?
[Re: Challenger 1]
#2379464
09/30/17 06:59 PM
09/30/17 06:59 PM
Posts: 10,760 North Dakota
6PakBee
North Dakota
I'm confused. Any good engine should have a brake specific horsepower number of around 0.5 lb/hp-hour. Assuming that an engine does more poorly than that at 0.7, at 600 hp that is 420 lb/hr of gasoline. At 6.07 lb/gal for gas, that is about 70 gal/hr. Why would you need fuel delivery rates over 100 gal/hr? What am I missing?
[Re: 6PakBee]
#2379499
09/30/17 07:54 PM
09/30/17 07:54 PM
Posts: 31,078 Oregon
AndyF
I'm confused. Any good engine should have a brake specific horsepower number of around 0.5 lb/hp-hour. Assuming that an engine does more poorly than that at 0.7, at 600 hp that is 420 lb/hr of gasoline. At 6.07 lb/gal for gas, that is about 70 gal/hr. Why would you need fuel delivery rates over 100 gal/hr? What am I missing? You aren't missing anything. Most high performance street engines need less than 50 gal/hour.
[Re: Challenger 1]
#2379500
09/30/17 07:55 PM
09/30/17 07:55 PM
AndyF
Yes there is a sump that comes with that pump. Very nice job there Andy. How did you handle the final finish? What is that? Finish is just rattle can paint. Flat black from NAPA, nothing special.
[Re: AndyF]
#2379506
09/30/17 08:11 PM
09/30/17 08:11 PM
6PakBee
North Dakota
I'm confused. Any good engine should have a brake specific horsepower number of around 0.5 lb/hp-hour. Assuming that an engine does more poorly than that at 0.7, at 600 hp that is 420 lb/hr of gasoline. At 6.07 lb/gal for gas, that is about 70 gal/hr. Why would you need fuel delivery rates over 100 gal/hr? What am I missing? You aren't missing anything. Most high performance street engines need less than 50 gal/hour. Thanks for the sanity check.
[Re: AndyF]
#2379508
09/30/17 08:17 PM
09/30/17 08:17 PM
CSK
Pattison Texas
I would've bought a tank like that for my car but I couldn't find anyone who made one. I have a '65 Coronet and I did not have any luck finding a tank with a built in recess. Ideally I'd like to have a tank with the built in recess for the pump and have the tank be about 1 inch deeper. I think there is room in the early B body cars for a slightly deeper tank.
I might end up having a custom tank built for my car since I'd like it a bit deeper than stock but a little narrower so the 3 inch exhaust will clear. My leaf springs are moved under the frame so everything is a little tight back there. I can probably get someone to weld up a stainless tank for me if I draw up a blueprint. Hot Rod City Garage builds very nice custom EFI tanks, I used one of theirs on customers EFI 69 Charger.
[Re: 6PakBee]
#2379628
09/30/17 11:51 PM
09/30/17 11:51 PM
fast68plymouth
So. Burlington, Vt.
I'm confused. Any good engine should have a brake specific horsepower number of around 0.5 lb/hp-hour. Assuming that an engine does more poorly than that at 0.7, at 600 hp that is 420 lb/hr of gasoline. At 6.07 lb/gal for gas, that is about 70 gal/hr. Why would you need fuel delivery rates over 100 gal/hr? What am I missing? It's not so much about what the pump flows.......its what the "system" flows, while maintaining the desired minimum pressure. Many fuel pump ratings are free flow......which doesn't really tell you anything useful.
