Re: Fender tag Trans decode
[Re: fast414]
#2244738
01/31/17 03:29 PM
01/31/17 03:29 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
Yes, the broadcast sheet will tell you the exact transmission in your car. Fender tag and certicard have only the 3 that says 4 speed manual. Another great case for a parts book, it will tell you the specific parts you car and engine size came with: gears, input shaft, front bearing retainer, bellhousing, clutch disc, throw out bearing and sleeve.
Now for an automatic we should all know that there are no 904's behind big blocks.
Talking b-bodies here: A 66-67 273 had a 904 A 66-67 318 had a 727 A 68-70 318 had a 904 All BB automatics have a 727 A383 2 bbl has a 3 disc high gear drum A383 4 bbl has a 4 disc high gear drum All 426 hemi's have a special 727 trans with a 5 disc high gear drum wider 2nd gear band and special parts around it for it to fit in there.
On the fender tag 66-68 for trans for all the different transmission listed above there would be a code 5, denoting automatic, not the specific one. Here is why.
What is the purpose of the fender tag? Why is it there? It tells what the body of the car is. So it only needs to say automatic or manual so the correct tunnel, welded linkage bracket on frame rail, and holes for the clutch pedals are put into the body when building it. Later on the build sheet tells the specific trans, pedals, rear axle to go in the car.
What is the certicard for? Why does it exist? It is for when you go in for warranty work, they put your card in the machine, lay a work order on top and slide the handle across it to print all that info on the work order for your car. Just like a credit card machine pre 1988, you remember those don't you?
[Re: fast414]
#2244797
01/31/17 05:03 PM
01/31/17 05:03 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
I agree !!!! I thought that the car came with a 18 4 speed also ....there must be a number or code somewhere that confirms that right !! ?? No , there is no code , it's a FACT , 440 in any body platform with a 4 speed transmission automatically gets an 18 spline HEMI 4 speed. now there is nothing saying the trans was not swapped out .
[Re: fast414]
#2245024
01/31/17 11:32 PM
01/31/17 11:32 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Don't worry about it, it came with an 18 spline, check the part number on the trans or pull the inspection cover to see if you can see the input to verify there is an 18 in it now.
Careful, your character's showing!
[Re: fast414]
#2245210
02/01/17 11:45 AM
02/01/17 11:45 AM
mopar346
OK, I never remember how they decode and I know an automatic does have a specific part number on them, so I kinda assumed it was the same with a 4 speed. Thanks for the info.
[Re: fast414]
#2245379
02/01/17 04:28 PM
02/01/17 04:28 PM
JohnRR
U.S.S.A.
If I don't have the build sheet .....what do I do ? Nothing you can do .
[Re: NANKET]
#2245387
02/01/17 04:33 PM
02/01/17 04:33 PM
JohnRR
U.S.S.A.
The cast in in raised numbers are for the individual pieces but they do not define the assembled transmission.
The one casting number that can tell you whether the trans is 23 spline or 18 spline in 68 and 69 only, on B/C bodies, is the tailshaft casting number .... ASSuMEing the trans has never been monkeyed with ... the tailshaft casting is different between the 18 spline and 23 spline because of the size of the 308 bearing and only the Hemi 4 speed in 68 and 69 had 308 bearings .
[Re: KOS]
#2245497
02/01/17 08:07 PM
02/01/17 08:07 PM
JohnRR
U.S.S.A.
IBM card is on its way and he found bits and pieces of the broadcast sheet..................will update with any new info. What new info would you be expecting ?
