Re: Vibration in 4th gear
[Re: 340swing]
#2244362
01/30/17 11:43 PM
01/30/17 11:43 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The trans mount is new. We are trying to figure out pinion angle is that the same as driveline angle? And if not where do I go to figure that out. I think acceleration or driving steady speed. Not there as car decelerates you feel it in shifter and pedals as soon as you push clutch in to shift to 4th and stays there until you get under 60 mp Your driveline angle is the relationship of the transmission angle, driveshaft angle, and pinion angle, and how they are phased to each other, you need to have an inclination meter to accurately measure the angles of each component as they sit at ride height in the vehicle, keep in mind the pinion angle changes (rotates upward)under acceleration by several degrees Hopefully you've eliminated any wheel/tire imbalance problem by trying another set of rims/tires? even a slipped/ruptured belt/cord in a tire can cause what appears to be a driveline vibration here's a few diagrams on driveline angle, keep in mind this is under acceleration conditions regarding some of the pics/measurements
[Re: 340swing]
#2244363
01/30/17 11:48 PM
01/30/17 11:48 PM
RapidRobert
if the driveshaft speed is the same when it acts up in 4th as it is in 3rd when it is OK that inclines me to think that the shaft/ujoints/angles are OK & that it is clutch or tranny or mount related & more the trans cuz of the shifter vibration.
[Re: 340swing]
#2244568
01/31/17 10:46 AM
01/31/17 10:46 AM
Posts: 6,393 Abilene, Texas
fastmark
Abilene, Texas
Fastmark do you have a 4spd? Have you tried anything yet. Yes. Its an AAR. It was an auto car. I put in a four speed many years ago. I've had it for 40 years. I've changed motors, mounts, balanced the flywheel, changed driveshafts and even a transmission. I can't imagine that it would be my rear end. I've got another car that I am restoring right now and then I'll start over from scratch. It's better than when I started trying to find it. I just don't drive over 65. Not much help but good luck to you.
[Re: 340swing]
#2244617
01/31/17 12:47 PM
01/31/17 12:47 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Surprised no one mentioned the pilot bushing, had a 383 Satellite act almost identical as described but seemed it was more on decal clutch and the pilot bushing was wollered out. All the 4 gear stuff is moving in 3rd same as in 4th only moving at a higher RPM related to speed. The only variance in 4th is the 1-3 gears are spinning at a different speed than the output shaft but that also happens to 2-3 when in 1st, 1&3 when in 2nd and 1-2 when in 3rd. The input as well as everything in front of the trans spin actually work harder in the lower gears but are under a load constantly. The output shaft, rear bearing, rear bushing and everything behind the trans work the same related to speed. So that leaves the cluster and the roller bearings in the back of the input, the cluster is under a load 1-3 and idle in 4th, worn roller bearings might create a vibration when not under a load. When in 4th, the input is locked to the output and the bearings in the rear have to keep it centered to a degree but it seems worn bearings here would cause more of an issue when spinning than when stable not to mention the synchro will do some centering as well. So if I was going into the tranny looking for this vibration I would be looking for worn roller bearings in the cluster gear or a worn cluster shaft. This is also an area where I have seen either ignored for fear of them falling apart or allowed to fall apart when being installed and then ignored. A heater hose is your friend.
Careful, your character's showing!
[Re: 340swing]
#2244646
01/31/17 01:31 PM
01/31/17 01:31 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Check the rear yoke. At one time it might have kicked out a u-joint and spread the yoke. Had that happen, not real noticeable except the joint fits loose side to side causing missalignement and vibaration higher speed.
[Re: 340swing]
#2244818
01/31/17 05:33 PM
01/31/17 05:33 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
First the car info: 70 challenger T/A 340 4spd. Engine and transmission are not original to car both 1971. Is the bellhousing original to the engine?
