Re: 80 or 130? [Re: RapidRobert] #2244510
01/31/17 03:06 AM
01/31/17 03:06 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Originally Posted By RapidRobert
Originally Posted By Jjs72D
You can also use a thin washer. This results in a slightly different position of the castle nut.
Ding ding ding I do believe we have a winna.
Actually, often times adding a washer will put the nut out on the threads too far to get a cotter key through the hole. The winner is to tighten the nut to the next hole. Gene
Re: 80 or 130? [Re: mickm] #2244567
01/31/17 10:37 AM
01/31/17 10:37 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Not if you used a shim and not a full thickness washer. Common practice when assembling certain items that only have 1 proper alignment. Absolutely nothing wrong with this approach.
Also, common practice to hit the torque and add more till castle nut alignment is reached, since this is never more than 1/6th of a turn. Also another acceptable solution with absolutely nothing wrong
Both solutions would be acceptable.
**Photobucket sucks**
Re: 80 or 130? [Re: 70Cuda383] #2245151
02/01/17 03:12 AM
02/01/17 03:12 AM
I totally agree!
