Re: Muriatic acid for rust removal
[Re: dd340]
#2241101
01/25/17 05:04 PM
01/25/17 05:04 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I saw Evaporust one gallon jugs in a Tractor Supply yesterday for $20, which was cheaper than the $26 per gallon at Harbor Freight. Amazon has some suppliers selling Evaporust in 3 gallon containers with a dipping basket for reasonable prices. https://www.amazon.com/Evapo-rust-Gallon...PTF7SKW9DRZX2MCNow that i know that Evaporust will only "chelate" a limited amount of rust, my revised strategy is to dip a non-delicate rusty part first in cheap white distilled Vinegar, rinse, then finish in Evaporust.
[Re: 360view]
#2241232
01/25/17 08:47 PM
01/25/17 08:47 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
This has been my method for a few years now. Vinegar is MUCH cheaper than Evapo, and works almost as fast.
[Re: dd340]
#2242099
01/27/17 02:40 AM
01/27/17 02:40 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Evapo-Rust is $16 per gallon if you order 5 gallons from Northern Tool & Equipment and pick it up at the store with no freight charge.
[Re: dd340]
#2242209
01/27/17 12:39 PM
01/27/17 12:39 PM
Posts: 8,354 fredericksburg,va
cudaman1969
fredericksburg,va
How often can evaporust be reused? I got very little use out of it, seemed like a one shot deal, open to the air kills it the fastest imo resealible container might help
[Re: cudaman1969]
#2242213
01/27/17 12:49 PM
01/27/17 12:49 PM
Posts: 5,366 Rancho Cordova, California (Sa...
hemi71x
How often can evaporust be reused? I got very little use out of it, seemed like a one shot deal, open to the air kills it the fastest imo resealible container might help Oh ya, never heard that about Evaporust before. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#2242336
01/27/17 04:27 PM
01/27/17 04:27 PM
cudaman1969
fredericksburg,va
How often can evaporust be reused? I got very little use out of it, seemed like a one shot deal, open to the air kills it the fastest imo resealible container might help Oh ya, never heard that about Evaporust before. Yea, even covered it didn't last long, depends on your wallet size.
[Re: cudaman1969]
#2242447
01/27/17 08:40 PM
01/27/17 08:40 PM
Posts: 1,849 South Bend
John Brown
South Bend
How often can evaporust be reused? I got very little use out of it, seemed like a one shot deal, open to the air kills it the fastest imo resealible container might help Oh ya, never heard that about Evaporust before. Yea, even covered it didn't last long, depends on your wallet size. My understanding on Evaporust is that it keeps eating on any rust particles in the solution even when put back into a sealed container, even when sealed from air. Also heard that straining or filtering the big and little chunks out of the liquid helps it last longer when not in use. Can't prove any of this by me as it's only hearsay on my part. I am still using that cheep old grocery store vinegar on things I need to de-rust.
[Re: dd340]
#2242682
01/28/17 10:04 AM
01/28/17 10:04 AM
Posts: 8,162 USA
360view
USA
http://www.evapo-rust.com/product-info/faqs/Acids "eat at" iron oxide on the surface of a part and send the oxygen off into the liquid in one direction, and the iron in another. ( scientificly: the acid helps the iron and oxygen ions dissociate from the metal surface) Strong acids can do this with iron atoms alone. Strong acids continue to "eat" iron atoms off the metal surface, turn them into ions, and these ions wander off into the liquid. All the metal could eventually disappear this way. The original part would disappear eventually. Evaporust is different. It "buddies up" to the rust molecule at the metal surface and carries the still combined iron and oxygen atoms away together into the liquid. This process has a special name: Chelation. The special difference is that once Chelation has got the iron oxide rust off the metal surface it does not continue and remove pure iron. The original part will not disappear. The above descriptions are simplifications. Please do not report me to the Chemistry departments that might have me tarred and feathered. ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
