Mechanical throttle stops
#2241027
01/25/17 02:40 PM
01/25/17 02:40 PM
Posts: 501 Easton, PA
68DART360
Easton, PA
Anyone use the moroso 65042 positive throttle stop? Any others or can anybody show me how they made their own? Thanks!
Re: Mechanical throttle stops
[Re: 68DART360]
#2241060
01/25/17 03:52 PM
01/25/17 03:52 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Had the Moroso, modified it a bit, took 1/2 of the throttle away as well as lowered shift points to make a 12.0 index out of a 11.6 car...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: 68DART360]
#2241111
01/25/17 05:18 PM
01/25/17 05:18 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
Ted FWIW that's probably the best way. Threw my kid in the dragster with it wowed up a bit but that was still 9.0's. Even with a stock stroke 440 it wasn't easy
[Re: 68DART360]
#2241115
01/25/17 05:20 PM
01/25/17 05:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
This is what I made for my 1050 dom...it slips into the hole at the center and rotates down over the rear stud to mount the carb.. worked very good for me ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: cgall]
#2241148
01/25/17 06:14 PM
01/25/17 06:14 PM
Posts: 4,993 new jersey usa
11secdart
new jersey usa
I have been using a modified version of the Moroso stop for almost 10 years now and have been pretty successful with it. However I changed my throttle cable bracket to a Jegs one so I could use two bolts to mount the stop otherwise it tends to move when only attached to the carb stud.
[Re: 68DART360]
#2241657
01/26/17 02:37 PM
01/26/17 02:37 PM
MR_P_BODY
MRpBody, how much to make me one that looks nice Are you using a 4500 type carb... if you are I'll give it to ya for shipping cost.. I will have to make up something for my new set up.. and I dont know if this would work on a 4150 style carb EDIT Where I have it set now and a rpm change on the launch and shift points I went from 9.0 to 10.0 .. I made 8 passes that day and never varied more than .006 on the day
