Re: A few questions about my transmission
[Re: ProSport]
#2242201
01/27/17 12:27 PM
01/27/17 12:27 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Bob...if it's real close, the oil pan can just sit on the drag link. I use a small piece of 1x4 board to let it sit on when I take the trans out. Just loosen up your plate bolts at the frame.
I don't think it's really necessary to put a bolt in sprag in a trans that's currently in good working condition. Just my opinion.
[Re: ProSport]
#2242203
01/27/17 12:36 PM
01/27/17 12:36 PM
Posts: 3,395 Pa
Hot 340
Pa
Thanks guys. I don't run a speedometer Cable, it looks like it's leaking a tiny amount of tranny fluid where the speedo Cable would attach. Is there a cap or something available to cap that off? use a 1 49/64" freeze plug. Dorman 555-036
[Re: ProSport]
#2242236
01/27/17 01:27 PM
01/27/17 01:27 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Thanks guys! It's nice to have a game plan.
[Re: ProSport]
#2242300
01/27/17 03:21 PM
01/27/17 03:21 PM
Posts: 916 MB,CAN
PC-CHARGER
MB,CAN
As already stated, the super or ultra sprags have six tapped holes where two additional holes have to be drilled in the case. The placement of these holes can either be marked out manually or one can purchase a jig from A&A to help with drilling these two holes. http://www.aandatrans.com/Departments/Chrysler-727-Trans/Bolt-In-Sprag.aspx?page=3 Drilling these holes on an older case is not a problem but on the later cases, there is a boss that you have to drill through and needs to be counterbored in order to make room for the socket head capscrew. This can be done on a mill or one can use a counterbore reamer to clearance the holes after the through holes are drilled.
[Re: Hot 340]
#2242329
01/27/17 04:19 PM
01/27/17 04:19 PM
Posts: 1,030 ohio
67mprfan
ohio
Thanks guys. I don't run a speedometer Cable, it looks like it's leaking a tiny amount of tranny fluid where the speedo Cable would attach. Is there a cap or something available to cap that off? use a 1 49/64" freeze plug. Dorman 555-036 (X2)
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: ProSport]
#2242363
01/27/17 05:18 PM
01/27/17 05:18 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
Yeah. I agree with the general sentiment. I wouldn't chase replacing the sprag. Do your burn outs starting out in second gear.
I have stripped axles and torn up an 8.75 rear, both at the hit, and never messed up the sprag.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: J_BODY]
#2242364
01/27/17 05:19 PM
01/27/17 05:19 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
....and I'd be more concerned about the front drum than the sprag. Aluminum or the billet steel piece for sure. Replace the drum before replacing the sprag.
[Re: John_Kunkel]
#2242454
01/27/17 08:51 PM
01/27/17 08:51 PM
dartman366
Mt. Vernon, Ohio
....and I'd be more concerned about the front drum than the sprag. Aluminum or the billet steel piece for sure. Replace the drum before replacing the sprag. same here, the only reason I changed mine was I was already in it.
[Re: moparx]
#2242778
01/28/17 01:56 PM
01/28/17 01:56 PM
ProSport
Akron, Ohio
Thanks guys. I don't run a speedometer Cable, it looks like it's leaking a tiny amount of tranny fluid where the speedo Cable would attach. Is there a cap or something available to cap that off? pm me with your mailing address and i will send you a screw on cap that has a rubber seal inside. no charge. PM sent, thank you sir!!!
[Re: 440Brian]
#2242783
01/28/17 02:06 PM
01/28/17 02:06 PM
ProSport
Akron, Ohio
Interesting. So basically the rubber pads will sit on top of your inner fenders, and the metal bar doesn't touch anything? I just wouldn't want anything sitting on top of the (outer)fenders.
[Re: ProSport]
#2242786
01/28/17 02:11 PM
01/28/17 02:11 PM
ProSport
Akron, Ohio
I got ahold of Chuck Lofgren and luckily he still makes and sells the shorty non-sfi blankets for $149, he only has one left and I won't have my money together til spring as I have other projects going on right now. I'll order one in the spring when he produces more of them.
[Re: ProSport]
#2243411
01/29/17 03:38 PM
01/29/17 03:38 PM
ProSport
Akron, Ohio
Ok thanks I'll buy one of those if my other efforts don't work. Harbor freight is only 15 min from my house.
[Re: ProSport]
#2243459
01/29/17 05:23 PM
01/29/17 05:23 PM
ProSport
Akron, Ohio
I just have an AR-Engineering motor plate.
