Time delay relay, Challenger 70 A01 light package #2241687
01/26/17 03:28 PM
01/26/17 03:28 PM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
To be sure, time delay relay, in A01 light package, is only to keep "on" the small tube light in the steering column, not the dome light?
70 Challenger, A66, 340 ci
Re: Time delay relay, Challenger 70 A01 light package [Re: Chal340] #2241718
01/26/17 04:19 PM
01/26/17 04:19 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
Yes, I believe it is. Dome light is controlled only by the 2 door switches and are wired hot and in parallel meaning they don't go through ignition circuit and either or both will turn that circuit on.
I have no info on the time delay relay because, even though I have the A01 light group, I've never found the relay. As such, I just wired a switch under the dash to activate my little blue ignition light manually.
It would be interesting to see what the time delay relay looks like or....perhaps if anybody has one for sale?
Re: Time delay relay, Challenger 70 A01 light package [Re: L.R Helbling] #2241728
01/26/17 04:37 PM
01/26/17 04:37 PM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
The time delay is round :
[img:center][/img]
part number is 2889585, and you can find it on ebay or Bill Rolik : http://www.billrolikenterprises.com/proddetail.asp?prod=2889565
Re: Time delay relay, Challenger 70 A01 light package [Re: Chal340] #2241749
01/26/17 05:07 PM
01/26/17 05:07 PM
Ottawa, Ontario
Ottawa, Ontario
Thanks!
Re: Time delay relay, Challenger 70 A01 light package [Re: Chal340] #2241912
01/26/17 09:51 PM
01/26/17 09:51 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
Hey Herve, wave
The time delay relay does power the light fixture on the steering column for the ignition switch and the title light fixture (switch panel).
Think of this time delay relay as operating like a one shot turn signal relay. Both relays work by stainless steel contact arms where one is wound with a wire coil. As heat builds up, these contacts heat up, bend and close, then when power is cut, the arm cools and disconnects.
The different is the time delay relay will turn on when a door is opened and continues to light those two bulbs after the door closes and does not re-trigger, but only continues on one time for about thirty seconds. Once the door opens again, this sequence starts over again.
The delay light relay should be mounted on the steering column with tape as they did at the factory. This serves as a heat sink since this is a thermal driven device. Hanging in mid air can cause this device to burn up rather quickly.
To test this relay, unplug and read the impedance between the 12 volt battery input and door jam ground terminals. It should read around -35 Ohms. If there is an O/L reading, the part is dead. Once plugged back in and the door opened and closed, the output terminal should read 12 dcv between and any clean exposed dash metal for a ground.
Re: Time delay relay, Challenger 70 A01 light package [Re: Slotts] #2242147
01/27/17 09:21 AM
01/27/17 09:21 AM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
Hello Jim and thank you for your answer. up
Re: Time delay relay, Challenger 70 A01 light package [Re: Chal340] #2242215
01/27/17 12:50 PM
01/27/17 12:50 PM
Ottawa, Ontario
Ottawa, Ontario
Excellent info on here on the A01 time delay relay and what it works on. I am thinking of purchasing one. Are all the relays currently on the market new reproductions? I'd rather trust something new as opposed to something like an NOS relay that has been slowly seizing up for 40 years. Can someone weigh in on this?
Re: Time delay relay, Challenger 70 A01 light package [Re: Chal340] #2242237
01/27/17 01:28 PM
01/27/17 01:28 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
You are welcome, Herve.
Thank you! I stock all of the parts for a delay light relay setup. I have NOS 2889565 relays, too.
Showing those relays in the picture from the back because the front of the bag is all white. wink
Email or call, if you are interested. Glad to help.
Re: Time delay relay, Challenger 70 A01 light package [Re: Chal340] #2242491
01/27/17 10:03 PM
01/27/17 10:03 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Its not something that could seize up maybe rust up there either good or not.
Re: Time delay relay, Challenger 70 A01 light package [Re: Slotts] #2268281
03/12/17 09:31 PM
03/12/17 09:31 PM
Ottawa, Ontario
Ottawa, Ontario
Originally Posted By JS Restorations
Hey Herve, wave
I was rummaging around the wiring harness near the ashtray and I finally found the time delay relay. I used your instructions to test the relay. It measured approx 33 ohms unplugged but I noticed that the relay is nowhere near the column. It is tucked up at the main harness just behind the ammeter. I will release it and tape it around the column as original and then test it with power hooked up to it. This was a very informative post. Thanks again. Lou
