Re: 1999 Dodge Ram 1500 5.9 ..fuel milesage?
[Re: GLR]
#2241711
01/26/17 04:08 PM
01/26/17 04:08 PM
Posts: 10,144 A Red State
SNK-EYZ
A Red State
Driving at 70 mph that's about all that you're gonna get with a stock truck.
The best I ever got with that era Ram 1500 4wd with a 5.9 V8 was 14 mpg on a good day, but usually it was 13 mpg.
It's still better than the 8-10 mpg that I get with my 99 Ram 2500 V10 truck.
[Re: GLR]
#2241820
01/26/17 07:27 PM
01/26/17 07:27 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Flyin' Ryan SCT customers report ~17 mpg in a 2wd Dakota 5.9 with his 'stock engine tune'. Plus about 35ft lbs of torque increase across the RPM band (the power increase is dyno proven on a few different trucks). You could consider a re-program but don't expect the same exact mileage. 4x4 vs 2wd and the 1500 is probably 1000-1500 lbs heavier.
The other thing you can do is a tune up to ensure everything is healthy. Check your plenum gasket, replace your plugs, wires, cap and rotor.
**Photobucket sucks**
[Re: 70Cuda383]
#2242431
01/27/17 07:54 PM
01/27/17 07:54 PM
Posts: 10,609 Freeport IL USA
poorboy
Freeport IL USA
The other thing you can do is a tune up to ensure everything is healthy. Check your plenum gasket, replace your plugs, wires, cap and rotor. Do you have a link to these guys? How much will it cost me to get 4 mpg better mileage and 35ft lbs torque? The 5.9 will be going into a hot rod, probably 1,000 lbs lighter then a last gen Dakota. Gene
[Re: poorboy]
#2242616
01/28/17 01:51 AM
01/28/17 01:51 AM
70Cuda383
Marysville, O-H-I-O
Here's his website. http://www.frptuning.comHe can send you a tune for a bone stock engine, and he can write you a custom tune for a modified engine from "just an intake and headers" to a fully built stroker with a big nasty cam, boost, nitrous, etc.
[Re: DaytonaTurbo]
#2245088
02/01/17 01:18 AM
02/01/17 01:18 AM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
My prior truck, a 2001 2500 standard cab 4x4 5.9 gas/5 speed 4:10 truck, would manage to pull 12-13 mpg if kept around 65-70. Beyond that, it plummeted: 80 would put me in the high 10's. All this was driving in the north east, not flatlands like Kansas.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: GLR]
#2245457
02/01/17 07:11 PM
02/01/17 07:11 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have found a couple mpg is pretty easy to get with any number of tricks, getting big gains is hard even combining everything I know. A couple of the best improvements come from putting in ford yellow fuel injectors, slotting and advancing the crank sensor. Next up thin oil helps, long tube headers with a high flow exhaust. Hughes airgap intake (although this costs you noticable low end TQ)helps mpg but I would not combine it with 3.55 gears and typical 4x4 size tires or anytowing. Skinny tires. No lower than 3.55 gears, the deeper they are the worse MPG, the magnum engines deliver the best MPG at low RPM (1400-1800) and lugging them pretty good. A short duration high lift cam helps. Thin head gaskets help bump the compression up and that helps also, I like to buy one mr gasket MLS head gasket seperate the layers and use one outer layer of the gasket for each side, it is the equivelant of milling about .040 off your heads.
Certain mods are not worth it just for MPG increase but other side benifits may make it worth while any how. The SCT with the custom tune is gonna be very expensive but should help MPG a lot as well as give you more power, same thing if you pay someone to swap in the thin head gaskets or if you buy brand new injectors(I usually get a set at the JY for about $50 so it can be very cost effective)
[Re: GLR]
#2245501
02/01/17 08:20 PM
02/01/17 08:20 PM
70Cuda383
Marysville, O-H-I-O
No need for custom tuning unless he gets into heads and cam swaps. Ryan has 'canned' tunes for bone stock and mild bolt on trucks (M1/airgap, headers, tb, etc). And costs less than the Airgap intake you just reccomrnded.
[Re: GLR]
#2245744
02/02/17 02:28 AM
02/02/17 02:28 AM
70Cuda383
Marysville, O-H-I-O
I'll let Dave answer about the yellow top ones. I'm running it's blue top in mine. Factory rated by ford at a few lbs/hr higher, but dodge runs a higher fuel pressure so they're about the same. Since I have custom SCT tune though, the pulse width was tuned to precisely what I need for 15.7:1 at cruise and 12.5:1 at WOT; which is a much higher pulse width than stock due to my Edelbrock heads and cam.
The benefit to me was that these ford injectors have a 4-hole spray pattern. I couldn't answer to whether they're better or not because I changed a lot at once when these went on, so I can't comment on improved economy or idle quality, throttle response, etc. I put them on because the price was right and I figured they wouldn't be any worse than the stock injectors
[Re: GLR]
#2249292
02/07/17 08:31 PM
02/07/17 08:31 PM
HotRodDave
Kalispell Mt.
The yellow ones flow about the same but have a much better spray pattern. They came on most 4.6 and 5.4 cars and trucks. If you need to order from autozone or something tell em it is a 97 F150 with a 4.6.
[Re: DaytonaTurbo]
#2249308
02/07/17 09:04 PM
02/07/17 09:04 PM
Challenger 1
Cincinnati, Ohio
Took a 3000 mile round trip in my buddy's 97 ram a few years ago. His was a 1500, 4x4, extended cab, 5.2/auto. We were picking up something for me so I was footing the fuel bill. 75mph got us 13mpg. 55mph brought us up to 18mpg. That's about a 40% improvement. The rest of the trip the speedo wasn't allowed over 55. This testing was done when we were driving through the flat lands with the cruise set.
I would imagine the 5.9 to be a little worse, especially if yours has had the death flash that knocks a bunch of timing out of the calibration. 3000 miles at 55mph? How many weeks did that take? I would helped with the fuel bill and drove 65-70, 55...
[Re: Challenger 1]
#2249619
02/08/17 12:18 PM
02/08/17 12:18 PM
DaytonaTurbo
Manitoba, Canada
I would imagine the 5.9 to be a little worse, especially if yours has had the death flash that knocks a bunch of timing out of the calibration. 3000 miles at 55mph? How many weeks did that take? I would helped with the fuel bill and drove 65-70, 55... We made the whole trip in 64 hours, including pickup time and time at the border. On the way back when we were pulling a trailer, if we were going much over 55, any little speed bump or rolling hill and that stupid transmission was constantly shifting in/out of overdrive.
[Re: GLR]
#2249624
02/08/17 12:21 PM
02/08/17 12:21 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
My 96 got 13mpg, cat converter went out, swapped in a high flow and went up to 15. That was 200k mile truck too.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
