Re: Power trunk option on 1971 Roadrunner. [Re: therocks] #2244714
01/31/17 03:10 PM
01/31/17 03:10 PM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Just as a matter of interest, this is the vacuum operated trunk release Fly and Rock speak of.
Although not correct for all, it lines up with and will mount in A B,C, and E cars.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2244779
01/31/17 04:33 PM
01/31/17 04:33 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I put an electric trunk release on my 70 Sport Satellite . . . donor car was a mid 80's Chrysler 5th Ave. You can get everything, switch, wire harness and trunk release (mounts directly where the old "key only" one does) and install with no issues . . .
I have had 69, 70 C bodies - all were vacuum release.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2244881
01/31/17 07:42 PM
01/31/17 07:42 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
If I recall correctly, several decades back, my father had a 1971 Newport that had a vacuum truck release. I'm positive it was vacuum powered unit, I'm not 100% on the 1971 model year.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2244967
01/31/17 10:15 PM
01/31/17 10:15 PM
Ottawa, Ontario
L.R Helbling Offline OP
Ottawa, Ontario
Those pics speak volumes. it is interesting to see how Chrysler used different sources of power to activate different devices on a car. Blown away that 4 completely different car lines "could have" used the same trunk latch........but didn't. Maybe they just saw it as a C body thing.
