I've never had a 10-1 motor so I'd like to at least stay in that range. The pistons with a 63cc head are advertised at 10.35-1.
My 416 street engine is 10.4:1... your cam is
what tells the story on compression... if the
piston is way up before the valve closes your
pressure will be low... on mine I can run 87
octane on the street with no problems but I
plan on running 93 octane when racing to be safe
and then slowly dial that down.. but I also have
.039 quench on it and 38* timing for max power but
I run 36* on the street... with 63cc chambers I think
your gonna need a thicker gasket to clear the head
EDIT
Mock it up with clay and a .039 gasket and see what
you have... give it some clearance for heat
