Re: How much is too much hard block
[Re: mopar dave]
#2324663
06/21/17 12:47 PM
06/21/17 12:47 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I like dependable simplicity..........plus I drive mine more than most at this power level n/a and over heating weather oil or water is a no-no in my book..........
[Re: mopar dave]
#2324674
06/21/17 01:07 PM
06/21/17 01:07 PM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
On a low deck block, filling to the bottom of the water pump hole can often result in water flow problems through the block, since at that height the fill can get to the bottom of the head bolt bosses....... Which can restrict/block the coolant from reaching certain areas of the block.
On an RB block, that same level of fill would have the bolt bosses 3/4" farther away from the filler.
[Re: mopar dave]
#2324740
06/21/17 02:45 PM
06/21/17 02:45 PM
fast68plymouth
So. Burlington, Vt.
That's a great little tidbit of info about the polished springs.
[Re: mopar dave]
#2324791
06/21/17 04:02 PM
06/21/17 04:02 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
what size oil cooler do ya think it would take to keep temps in check? fan? after the cost of all that you could just put your current cooler in a water tank circulated with coolent from the heater tubes from the water pump,A tank 1" bigger than the cooler on all sides.
[Re: mopar dave]
#2324979
06/21/17 11:20 PM
06/21/17 11:20 PM
Clanton
northern,Ohio,USA
i currently dont have any oil cooler. To save a few bucks you could get 1 off a motorcycle but cooling with water can be better than in air.
