Courtesy lamps 1970 Challenger #2238590
01/21/17 07:36 PM
01/21/17 07:36 PM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
About courtesy lamps with the A01 package, where are they fixed under the dash?
If someone can put pics. Thanks
70 Challenger, A66, 340 ci
Re: Courtesy lamps 1970 Challenger [Re: Chal340] #2238596
01/21/17 07:49 PM
01/21/17 07:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there wasn't a "courtesy lamp" listed as included with the A01 package, are "we" talking a convertible?
Re: Courtesy lamps 1970 Challenger [Re: 6bblgt] #2238601
01/21/17 07:59 PM
01/21/17 07:59 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there was a "map light" mounted under the dash
- not a great pic of the light, but here's the toggle switch for it. scope
Re: Courtesy lamps 1970 Challenger [Re: 6bblgt] #2238604
01/21/17 08:12 PM
01/21/17 08:12 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Same thing as the map light - http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Challenger0024.jpg
Re: Courtesy lamps 1970 Challenger [Re: Alaskan_TA] #2238615
01/21/17 08:35 PM
01/21/17 08:35 PM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
Not for a convertible but a 2 doors 70 Challenger with A01 package.
Barry, on your document, there is " map and courtesy light " with A01 package.
And I saw on the A01 wiring, these 2 courtesy lamps right and left.
Re: Courtesy lamps 1970 Challenger [Re: Chal340] #2238625
01/21/17 08:49 PM
01/21/17 08:49 PM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
In this wiring, there are these 2 courtesy lamps.
Re: Courtesy lamps 1970 Challenger [Re: Chal340] #2238634
01/21/17 08:56 PM
01/21/17 08:56 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
those are marked "(CONVERTIBLE)" in the factory shop manual wiring drawings
they are part of the rear body wiring harness & replace the dome light, they are mounted in the rear seat trim panels
Re: Courtesy lamps 1970 Challenger [Re: 6bblgt] #2238890
01/22/17 06:52 AM
01/22/17 06:52 AM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
Ok, thank you.
The number of this courtesy lamp was 2864024?
In fact, map and courtesy lamps had the same housing?
Re: Courtesy lamps 1970 Challenger [Re: Chal340] #2238894
01/22/17 07:21 AM
01/22/17 07:21 AM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
Ok, I found.
for the courtesy, on the convertibles, it was only sockets on the rear panel.
And this housing #2864024 was only for the map light.
right?
Re: Courtesy lamps 1970 Challenger [Re: Chal340] #2238895
01/22/17 07:40 AM
01/22/17 07:40 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the convertible "courtesy lamps" don't have a separate housing
the bulb fixture snaps into the bottom/backs of the rear seat side panels scope
70 challenger vert courtesy lamps.jpg70 challenger vert courtesy lamps LH.jpg70 challenger vert courtesy lamps RH.jpgjh27 photo 1.jpg
Re: Courtesy lamps 1970 Challenger [Re: 6bblgt] #2238896
01/22/17 07:51 AM
01/22/17 07:51 AM
FRANCE, Paris
Chal340 Offline OP
Chal340  Offline OP
FRANCE, Paris
Ok, thank you, it's clear now.
and map light was fixed directly on the frame.
