Oil lines for Indy block
#2238165
01/20/17 11:06 PM
01/20/17 11:06 PM
Posts: 740 WA
JD Dart
WA
Will I'm tired of of doing this going to take a break. Aren't Mopars fun
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Oil lines for Indy block
[Re: sasquatch]
#2238546
01/21/17 05:55 PM
01/21/17 05:55 PM
Posts: 740 WA
JD Dart
WA
I drilled a big hole up front t/c side that way those small holes might let some oil to drain back and the vacuum pump can pull crankcase pressure up through the big hole up front. All the work was to provide oil to the lifters edm oiling and T&D rocker arms for the new heads this year fingers crossed Al knows the story on that.
[Re: JD Dart]
#2238613
01/21/17 08:33 PM
01/21/17 08:33 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Unfortunately I have to do the same eventually to a KB block that was not done as ordered as well.
[Re: JD Dart]
#2238735
01/21/17 11:36 PM
01/21/17 11:36 PM
Posts: 292 NY
challenger451ci
NY
I did something similar with mine. Not a lot of fun, but it works!
[Re: JD Dart]
#2239666
01/23/17 05:31 AM
01/23/17 05:31 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
When we ordered the block, didn't order it with lifter oiling. However, now that we will come to drag week, the plan changed. Have to get pushrod oiling upstairs instead of spray bars to survive. Thought about different possibilities with lines similar to thos in the pictures, but then one machined shop volunteered to drill the holes for us. However, they screwed it up a bit, everytime the drill bit pushed throught the lifter bore it guided the drill bit a little. The drivers side went upwards, and the passanger side down, and the two last ones went through to the cam tunnel... Not a big deal though, blocked the channel before them and will oil the two last ones with lines. The lifter bores will be sleeved with about .040"- .060" hole in each sleeve. The lifters will be Jesel. Should have installed an aluminum rod through the lifter bore when drilling and it would propably have turned out just fine, will try that with the next block! ![](http://i1162.photobucket.com/albums/q530/jyrki6664/vipdw37_zpsugt7n7mr.jpg)
Plynouth VIP '67 TT IC EFI
[Re: wyldebill]
#2239720
01/23/17 12:34 PM
01/23/17 12:34 PM
Posts: 740 WA
JD Dart
WA
Holley jet I'll start out with 60 and see if that's enough. with the 1/8 pipe fitting in the block just drill out the fitting to 1/4 by 32 thread screw in the jet if it's no enough just change jets
[Re: JD Dart]
#2239781
01/23/17 02:06 PM
01/23/17 02:06 PM
Al_Alguire
Las Vegas
IMO you will be fine going way down from a 60 jet. I had a .029" restrictor in my Cuda with no issues.
[Re: JD Dart]
#2240255
01/24/17 03:06 AM
01/24/17 03:06 AM
jyrki
Finalnd, Perkele
At the point where you are starting to have problems with pushrod ends and adjusters or lifters. If you don't have any problems, there is no need for doing things differently.
[Re: JD Dart]
#2240360
01/24/17 12:56 PM
01/24/17 12:56 PM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
What heads and/or rocker systems typically need something like this? Looks like a huge PITA. I've had my hands in some fairly serious Mopar builds and never seen one that needed this before.
