Page 6 of 6 1 2 3 4 5 6
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2538429
08/19/18 03:11 AM
08/19/18 03:11 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Birdman
Re: Why so few Procharger Mopar builds? [Re: hemi-itis] #2538436
08/19/18 03:54 AM
08/19/18 03:54 AM
CO
crankn101 Offline
crankn101  Offline
CO
Originally Posted By hemi-itis
Thats one BAD car
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2538438
08/19/18 04:47 AM
08/19/18 04:47 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I love a good Pro-Charger as much as anyone.
But I have an 11 to 1, flat tappet cammed small block that I can drive any where in the country on 89 pump swill. I have a plate nitrous system under the carb which I pieced together for less than 600 bucks, weighs next to nothing and inhibits none of the car's streetability.
I arrive at the track, bolt in a bottle, pour in some 114 octane and run a best of 9.43-139.
If that makes me a typical cheap, old school, stuck in the eighties Mopar guy...so be it!
IMG_0045 - Copy.JPG15369007_817669805039642_8844590694082736413_o - Copy.jpg
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Why so few Procharger Mopar builds? [Re: MoparBilly] #2538447
08/19/18 08:27 AM
08/19/18 08:27 AM
Mo.
racerx Offline
racerx  Offline
Mo.
How big of a shot you hit it with?
Re: Why so few Procharger Mopar builds? [Re: crankn101] #2538449
08/19/18 08:28 AM
08/19/18 08:28 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Thats one BAD car
Isn't that the tooth jerker smoke ?
Re: Why so few Procharger Mopar builds? [Re: racerx] #2538469
08/19/18 11:03 AM
08/19/18 11:03 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Probably cost....I have priced them, they are not a cheap. And pretty much requires an aftermarket block, which nobody has anymore. Thought about doing it many times.
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2538484
08/19/18 11:48 AM
08/19/18 11:48 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Exhaust primaries
Boffin Emeritus
Re: Why so few Procharger Mopar builds? [Re: MoparBilly] #2538494
08/19/18 12:11 PM
08/19/18 12:11 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
That's my kinda ride.MUST be streetable on pump junk then change a pulley and add octane at the track.If you were real old school,it would be a huffer! My heap is 3700 lbs.Mid 9's with 4 lbs on the pump and low 9's with 6 lbs on c12 through the exhaust and tail pipes getting choked!
I put dumpers on and will step on it this fall in the good air!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Why so few Procharger Mopar builds? [Re: 70VcodeCoronetRT] #2539562
08/21/18 01:44 PM
08/21/18 01:44 PM
Maryland, USA
Raymond Offline
Raymond  Offline
Maryland, USA
I did a small block procharger
build 20 years ago.THE Average mopar
guys a cheap on performance builds.
They all build 440 because it takes
little imagination to build big blocks.
Re: Why so few Procharger Mopar builds? [Re: Raymond] #2539641
08/21/18 04:08 PM
08/21/18 04:08 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yep you nailed me for sure. Zero imagination BB for me smile
Re: Why so few Procharger Mopar builds? [Re: Raymond] #2540384
08/23/18 12:04 PM
08/23/18 12:04 PM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
My Procharged BBM started life as a 440, and you said "all." So I guess I just shot your theory all to heck. cool
