426 Hemi exhaust manifold question
#2237313
01/19/17 04:25 PM
01/19/17 04:25 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Ok I have searched everywhere and cannot find anything about the vertical tube? vent? whatever it is, that goes just in front of the heat riser. The repo manifolds have the casting but are not machined. I have looked in the FSM and cannot find a reference on it. What is it's purpose and who has the parts.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
Re: 426 Hemi exhaust manifold question
[Re: MOPARMIKE69]
#2237388
01/19/17 06:48 PM
01/19/17 06:48 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The larger tubes above the heat riser direct exhaust gasses to the intake to heat the plenum, the smaller nipple in front of them is for the tube (white insulated tube in pic below) that heats the choke; it is hot air only, no exhaust gasses.
[Re: John_Kunkel]
#2237412
01/19/17 07:15 PM
01/19/17 07:15 PM
MOPARMIKE69
Nashville, TN
Yes John that is exactly what I was asking. So what is the natural metal line running along the white sleeved line? Is that a double clip holding the natural line and the white sleeved line? And finally does anybody have these parts. The tube that goes through the manifold, the line with the white sleeve and the clip?
Thank you so much for the help. I have been searching for this for weeks.
[Re: MOPARMIKE69]
#2237513
01/19/17 09:28 PM
01/19/17 09:28 PM
John_Kunkel
Rio Linda, CA
The natural metal tube is hooked to the air cleaner and supplies a clean air source, the vacuum inside the choke module pulls the clean air down into the exhaust manifold where it is heated by the heat exchanger inside the manifold and is then drawn into the choke module through the insulated tube to heat the spring. Most of the choke parts are available on e-bay. http://www.ebay.com/sch/i.html?_from=R40...amp;_sacat=6000
[Re: John_Kunkel]
#2237885
01/20/17 02:22 PM
01/20/17 02:22 PM
MOPARMIKE69
Nashville, TN
Thank you for your help John!
