Re: Low oil pressure on rebuild
[Re: Interceptor72]
#2235918
01/17/17 11:16 AM
01/17/17 11:16 AM
Posts: 5,168 CT
GTX MATT
CT
What main bearings are in it?
[Re: Interceptor72]
#2236002
01/17/17 01:39 PM
01/17/17 01:39 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
One thing I noticed about the rockers, is that when I primed the oil pump, I had the oil filler cap off. Oil from the rocker right under that hole went SHOOTING waaayy out over the fender and on the ground. never saw anything like that on any other motors I ave primed, but have never built a motor with shaft mounted rockers before.
Come to think of it, that is one more thing I think I need to check...pull the oil cap with the engine running and see if there is a crazy amount of oil coming out.
Here is a link to an article that shows the rocker setup, look about halfway down. Six Pack build I ripped this quote off from a website. Speaking of oiling, the holes in the rocker shafts have to be properly aligned with the oil gallery in the head so that the rockers can be fed the lubrication they need. Stock rocker shafts make this easy with a notch that should always go to the left and point down when the shaft is installed. But an aftermarket shaft may or may not have the shaft (this one doesn’t). The easy way to get this right is to always install the shaft with the small oiling holes pointed down and angled toward the exhaust ports. Page also recommends removing one or both of the endcaps so that you can properly clean and inspect the I.D. of the shaft. You don’t want any grit left behind going into the rockers and ruining your valvetrain as soon as you crank the engine. Replacement plugs should be available from the manufacturer.I think once you fix this issue you should be in good shape.
1974 Roadrunner
1967 Charger
[Re: madscientist]
#2236110
01/17/17 04:23 PM
01/17/17 04:23 PM
Posts: 26,024 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Shimming the relief spring will have no affect if the pressure drops with temperature (oil thinning out). Since he had 50 psi when cold, the spring will hold at least that pressure.
[Re: Interceptor72]
#2236351
01/17/17 10:41 PM
01/17/17 10:41 PM
fast68plymouth
So. Burlington, Vt.
If messing with the rockers/shafts doesn't prove fruitful, and you cut open the filter and don't find anything alarming inside, I would then investigate the roller lifters being the issue. Unfortunately, if you have most aftermarket heads you can't get a good view of the lifter valley without removing the intake and valley cover.
If you turn the motor over and cycle each lifter through it's full range while running the priming tool, you may find that several will have a huge flow of oil running out the bottom of the lifter bore as you get near full lift.
This is actually a pretty common situation, but most of the time there are only a few that really gush, and the ones that do only do it for a few degrees of rotation.
It's the occasional combination of a particular set of lifters, cam base circle, and the exact location of the oil holes in the block that ends up with most or all of them showing a large amount of oil flowing out from under the lifter. When that's the situation you have, you end up with oil pressure problems like you're describing.
The "correct" solution for that is to bush the lifter bores, and only drill small feed holes as high as possible and still properly pressurize the lifter.
Obviously the engine is together now, so that's not a very desirable path at this point.
There are some hyd roller lifters that use fully shrouded .700 wheels and they would basically solve this issue....... If in fact this is the reason for your low oil pressure.
Of course, more than likely youd end up needing different length pushrods.......just because that's how it usually goes.
[Re: Interceptor72]
#2236371
01/17/17 11:02 PM
01/17/17 11:02 PM
Posts: 76 Florida
Interceptor72
OK, thanks for all the tips. First, I will make sure my rockers are set up properly and don't appear to be getting too much oil when running. Then I'm going to pull the filter for inspection and change the oil to 10/40. Last, I will try to check out the lifters and see if I can get them to gush at full lift while priming. I am doubting that it's a lack of volume from the oil pump, as right now there is more oil making it to the top of the heads than I have seen in any other car I have ever owned...at least as far as I can ascertain thru the oil filler cap. I'm going to pull a valve cover see how much comes out. I think it may be a lot. Which really seems to point to something being up with the rocker system. It also makes me think that there is not (I hope!) a huge internal hemorrhage, or else how would so much oil make it to the rocker system? Thanks everybody. I will report back my findings
[Re: Interceptor72]
#2236401
01/17/17 11:32 PM
01/17/17 11:32 PM
RapidRobert
I'm going to pull a valve cover see how much comes out. I will report back my findings Please hurry!
[Re: Interceptor72]
#2240175
01/24/17 12:32 AM
01/24/17 12:32 AM
RapidRobert
when you were redoing things nothing jumped out at you that had excessive clearance or play? Is the oil shooting up or sideways & if sideways toward ex or intake. I would preoil with the drill to be able to modulate the psi/leak & be easier to spot where the big clearance is at. Keep us posted.
[Re: RapidRobert]
#2240197
01/24/17 01:01 AM
01/24/17 01:01 AM
Posts: 76 Florida
Interceptor72
when you were redoing things nothing jumped out at you that had excessive clearance or play? Is the oil shooting up or sideways & if sideways toward ex or intake. I would preoil with the drill to be able to modulate the psi/leak & be easier to spot where the big clearance is at. Keep us posted. The part that is really obvious is the little hole at the top of the rockers that is meant to let oil leak out onto the valve stem and spring. A lot of oil shooting out of those holes, toward the exhaust side. It is a pulse, so I know it is not getting a continuous feed from a cam bearing groove. But it just seems like WAY more oil than is necessary. Every other engine I've ever seen run with the valve covers off, you get a little dribble of oil coming out to lube the valve stems (at an idle, that is.) This is just a whole bunch of oil coming out.
[Re: Interceptor72]
#2240221
01/24/17 01:34 AM
01/24/17 01:34 AM
RapidRobert
Alright, it sounds like the pushrods need to be internally restricted. I ain't never done (yet) myself but others have & lets find out what the procedure is. EDIT You mentioned roller lifters & I ain't up on them but they might need the oil to be restricted that is going into them & deal with it that way (not sure). Well we know where the problem is now.
[Re: Interceptor72]
#2240265
01/24/17 03:34 AM
01/24/17 03:34 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Yeah this will be the fix ^ block the push rod hole .
1963 Plymouth Max Wedge 1971 Barracuda
[Re: Interceptor72]
#2240332
01/24/17 11:56 AM
01/24/17 11:56 AM
Posts: 716 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
what is the part number for the lifters?
I went on the comp site and they made no mention of PR oiling. (that doesn't mean much)
Joe
Without Data, you’re just another guy with an opinion.
[Re: Interceptor72]
#2240418
01/24/17 02:34 PM
01/24/17 02:34 PM
fast68plymouth
So. Burlington, Vt.
Comp makes no mention of PR oiling for their mopar hyd roller lifters, but that doesn't mean they don't have it. They could be using the same bodies for bb, sb, and amc, and just using different link bars for each application......... In which case they would have PR oiling.
I would back off a couple of adjuster screws and with the priming tool verify if oil is coming out of the top of the pushrod. If it is, replace the pushrods with some that have no oil holes.
