Re: Holley Street Dominator modification
[Re: MadMopars]
#2301091
05/08/17 12:08 PM
05/08/17 12:08 PM
Thumperdart
State of confusion
Just a quick update...
I spent some time this afternoon blending the runners into the plenum. The picture doesn't do it much justice, nor am I finished but the corners are coming along.
I'm leaning towards thinning the dividers down a bit but will probably try to keep them more rounded than knife edged. I was told knife edging was actually worse for flow although I personally haven't tested that theory.
I missed your last post Mr. P but I can imagine cutting the intake in half made things a ton easier to work on. Part of me wants to keep track of how many hours I'll have in this intake, the other half doesn't. Hope it's worth the hassle in the end. Time will tell I suppose. Looks great man and I too have been told by a few sharp dudes that a round and gentle radius is better that razor sharp like I keep seeing WILSON Manifolds do and makes no sense. Look at an airplane wing.................
[Re: madscientist]
#2301093
05/08/17 12:10 PM
05/08/17 12:10 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
Just a hint,
On a well jetted motor, With the single plane Street Dominator the #1 and # 7 cylinders will tend to run a little lean (even compared to many other single planes I've worked with)...I believe because (#1 it's a relatively small plenum) and (#2) the cylinders are firing directly after the #2 and #5 (respectively) holes, so the hole firing immediately before them tends to rob a little charge from them. I think the old Mopar "popsicle sticks' tried to correct it some but with a flat floor what I've done (and I think tends to help power) is I make the #1 and #7 a slightly larger and trapezoidal (I call it 'Gumby's head') at the top of the runner so they are maybe 1/4 to 3/8" taller than the adjacent runner that want to steal from it. I do quite a lot of radius work from each runner into the plenum roof as well on all the runners. The walls between I put a gentle radius on but they stay comparatively "fat".
But your mileage/MPH may vary, lol
[Re: MadMopars]
#2301262
05/08/17 05:45 PM
05/08/17 05:45 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
[quote=MadMopars] I'm leaning towards thinning the dividers down a bit but will probably try to keep them more rounded than knife edged. I was told knife edging was actually worse for flow although I personally haven't tested that theory. Yes, its been proven a rounded edge is better then a knife edge. Also, there are bits for aluminum and they do have wider spacing between the cutting edges. I too know well about the bits clogging up. Theres a correct term for the aluminum bits, but that eludes me at this moment. Nice work though.
[Re: Sport440]
#2301356
05/08/17 09:12 PM
05/08/17 09:12 PM
Thumperdart
State of confusion
Aluminum burrs iirc and mine never clog even dry........
[Re: Sport440]
#2301941
05/09/17 07:41 PM
05/09/17 07:41 PM
Posts: 610 long time lurker, short time p...
PorkyPig
Aluminum burrs iirc and mine never clog even dry........ Non-ferrous is probably the term you were looking for. Grinder's grease or a good porting lubricant can help with keeping even regular burrs from clogging up with aluminum. Eastwood's grinder's grease, which is kind of like wax stick, fills in the grooves on the bits so they don't get jammed up with aluminum as easily. Grind a little while, clean the burr with a wire brush, re-treat and grind some more.
