Challenger Upper Cowl
#2232360
01/11/17 05:24 PM
01/11/17 05:24 PM
Posts: 559 Newark Valley, NY
jim6346
Newark Valley, NY
Hi Everyone,
I am in the process of restoring a 1970 Challenger 440-6. The upper cowl is very rough and should be replaced. I am hesitant as this is the only place on the body with the numbers, and they are very clear for a wonder. I checked the trunk rails and core support, but neither has the numbers. Trunk rails were pretty shot, but the core support is definitely original and pretty solid.
Anyway, anyone has any suggestions? I want to keep it as close to original as possible.
Also, I see they offer two different upper cowls, with screw in and snap in screens. It look slike this one had screw in, does it make a difference?
Thanks, Jim
Re: Challenger Upper Cowl
[Re: jim6346]
#2232372
01/11/17 05:43 PM
01/11/17 05:43 PM
jim6346
Newark Valley, NY
Hi GTS440, Yes, the door sticker is still there and the torque boxes are all there. Not sure about the two lines, didn't have any when I got the car. She was pretty rusty when I got her ![frown frown](/ubbthreads/images/graemlins/custom/frown.gif) After a lot of research, I found that not all early 70 Challengers had the stamp on radiator support (found out on here actually). Thanks!! Jim
[Re: moparmarks]
#2233147
01/12/17 10:38 PM
01/12/17 10:38 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
I'd cut out the cowl numbers and throw then into the glove box along with pictures of the process. yup why make more work for yourself then you have to. even putting numbers on a repo cowl will not cover up it being a repo part.. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: Stanton]
#2233199
01/12/17 11:40 PM
01/12/17 11:40 PM
Posts: 12,495 Western Colorado High Desert
moparmarks
I'd swap the dash into a decent body, cut out all the numbers and weld those in the new body too! The "rebody police" can go do you-know-what to themselves!! Do what YOU'RE comfortable with, its your car. The "re-body police and the FBI. Yep that seems to be the Canadian way. That's why we don't buy cars from Canada. Just don't sell the car to an American and we won't have to send the Goon Squad up to cut your nuts off.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: jim6346]
#2233202
01/12/17 11:47 PM
01/12/17 11:47 PM
Posts: 91 Alaska, USA
Jalaska907
Alaska, USA
Just my opinion, but I feel if you take photos of before and after, and cut out the old stamped numbers, and weld it into the new re pop panel, that is the best route to go. Its not that much more work to cut out the numbers and patch it into the new.
Justin Baldwin Kenai, AK
[Re: jim6346]
#2233915
01/14/17 06:25 AM
01/14/17 06:25 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
OK, but still wondering about the core support? Anyone else have one with no numbers?
Thanks, Jim I have 5 1970 Challengers and they all have the VIN in the core support.
[Re: jim6346]
#2233968
01/14/17 12:38 PM
01/14/17 12:38 PM
Posts: 4,924 new berlin wisconsin
Mr T2U
it's not a challenger. but i had a 71 cuda project car that didn't have ANY numbers stamped on the body. no numbers on the cowl or radiator support. the front end sheet metal was original. the car had a 70 rear clip, sectioned in the middle of the doors and windshield pillars, welded on sometime in it's life. E-bodies don't have numbers stamped in the trunk rails.
perception is 90% of reality
[Re: jim6346]
#2233989
01/14/17 01:35 PM
01/14/17 01:35 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Thanks, Jim Are you looking in the correct area ??? Its usually on the driver's side, on the inside{facing the engine} of the support...And they're very easy to fill in with a repaint sometime in the vehicle's life..
