Re: Brake help
[Re: JohnGlenn]
#2233468
01/13/17 01:29 PM
01/13/17 01:29 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Did you look at the brake math spreadsheet and find the optimum master cylinder size for those calipers?
Re: Brake help
[Re: JohnGlenn]
#2234091
01/14/17 05:32 PM
01/14/17 05:32 PM
RapidRobert
I could see a less than perfect size booster/MC causing a problem but from the descrip it sounds like there is a mechanical failure/issue somewhere. A suggestion since the booster (even if undersized) & the MC are good/bled is rehook the MC line to the front discs next to the firewall port only & bleed it out & work with them first & see if I can get it to straighten up
Re: Brake help
[Re: JohnGlenn]
#2234449
01/15/17 02:36 AM
01/15/17 02:36 AM
Posts: 35 San Antonio.TX
JohnGlenn
San Antonio.TX
So, I kind of confirmed my suspicions tonight. I eased it over to an empty parking lot right outside my neighborhood, instead of being nice I figured the best vacuum would be achieved by jumping all over it. So, I lit them up from a 20mph roll, backed off and jumped on the brakes...front end dropped and locked both front wheels up, might have locked rear also but I'm unsure. So it's settled, lack of vacuum.
Re: Brake help
[Re: JohnGlenn]
#2234458
01/15/17 02:51 AM
01/15/17 02:51 AM
RapidRobert
Alright, would that be the eng not generating enough vac (wild cam) or wrong booster?
Re: Brake help
[Re: JohnGlenn]
#2234485
01/15/17 03:51 AM
01/15/17 03:51 AM
RapidRobert
I ain't into PB but iirc someone (on here) said that either 12 or 14 in hg is needed for good functioning. If that ain't available, is there a booster type that will function with less? Or maybe a vac pump.
Re: Brake help
[Re: Sxrxrnr]
#2234600
01/15/17 01:11 PM
01/15/17 01:11 PM
RapidRobert
I would myself prefer to go non-power brake in that case. that'd be my choice (even with adequate vac): less weight/better brake feel/simpler system/more room. EDIT From what I understand PB does not give increased braking, it just requires less leg effort for the input side.
