Re: BDS intake Modman style [Re: Clanton] #2235152
01/16/17 03:33 AM
01/16/17 03:33 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Will it work and run....sure. Will it be good....highly unlikely. That is going to have no plenum volume and I think the signal will be terrible.
Re: BDS intake Modman style [Re: Clanton] #2235217
01/16/17 12:27 PM
01/16/17 12:27 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks RTSrunner,lockjaw-express,Monte_Smith for your info!I agree on the dual carbs over single.The plenum has volume but it is split in 1/2 and with a short plenum I am sure it will lack in fill volume but maybe suffer more at upper rpm.I wont add much to the plenum with a 1/2" plate so it is what it is with that and a larger carb spacer is not a good band aid.
Re: BDS intake Modman style [Re: Clanton] #2235229
01/16/17 12:43 PM
01/16/17 12:43 PM
Ohio
lockjaw-express Offline
Ohio
Here is a pic of my EFI modman, with a single carb just to move it around...it does take a LOT of pump shots to start it, and smooths out when warm.
I now know why I was told to run two carbs!
Re: BDS intake Modman style [Re: Clanton] #2235242
01/16/17 12:58 PM
01/16/17 12:58 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks for the pic,info.With my blower I am used to more pump shot.
Re: BDS intake Modman style [Re: Clanton] #2235279
01/16/17 01:54 PM
01/16/17 01:54 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Clanton,Did you decide not to use the blower or break it? Or is this only a test?
RT
Re: BDS intake Modman style [Re: RTSrunner] #2235301
01/16/17 02:22 PM
01/16/17 02:22 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
RT
I want to drive it some on the street so I am n/a this yr and it lets me check for any trans,carb adjustment.
