Re: Dragweek 2017 Questions
[Re: Dart451]
#2263699
03/05/17 02:50 PM
03/05/17 02:50 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
We are registered for dragweek!!
Looking at one of two possible cars tomorrow. Wife is excited to be in the event. How do you register without knowing what ar you are using? I had to fill out a bunch of information about the car I was taking when I signed up... it would have been easier to pick the car later. Thanks
A new iron curtain drawn across the 49th parallel
[Re: Dart451]
#2263703
03/05/17 02:55 PM
03/05/17 02:55 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Just show up with a car, thats all they care, there is lots of people that don't bring what they planned on.
68 Barracuda Formula S 340
[Re: Dart451]
#2264313
03/06/17 02:59 PM
03/06/17 02:59 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I have not found much for a off the shelf piston. What the most anyone has sprayed on KB piston? If a stroker crank isn't out of the question, that can help you in more than one way. Lots of piston choices plus you can make decent power with a farm tractor reliable package. 9:1 will get you 500 HP/600 FT/LBS naturally aspirated by 5000 RPM. It makes a highway friendly 3.23 gear work with a mild converter and regular gas. Add spray or boost to taste. Kevin
[Re: Dart451]
#2264565
03/06/17 10:19 PM
03/06/17 10:19 PM
Bad340fish
Tulsa OK
I agree on the gear changing, don't do it. Or if you are really dead set on it go out and change them twice everyday for a week and see how you feel about it before you commit to doing it on drag week. I get cranky changing tires twice a day so I might be the wrong guy to ask lol.
I have run 3.91 gears with a 26" tire on 5 drag weeks. Just find a compromise between your motor cruising happy and your ability to hold your foot in that position for hours. My 416 was happiest at 3000RPM last year and that took such a small amount of throttle it was uncomfortable after about day 3.
[Re: Dart451]
#2264632
03/07/17 12:04 AM
03/07/17 12:04 AM
67autocross
Manitoba Canada
I will find a set of tall rear tires instead for the drive, I have a 4:10 spool or 3:91 sure grip to pick between. The car is getting a 340 with a solid lifter cam that when I had it on the dyno a few months ago would rev past 7000 so maybe I won't need to touch the gears.
[Re: 67autocross]
#2264674
03/07/17 01:16 AM
03/07/17 01:16 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I will find a set of tall rear tires instead for the drive, I have a 4:10 spool or 3:91 sure grip to pick between. The car is getting a 340 with a solid lifter cam that when I had it on the dyno a few months ago would rev past 7000 so maybe I won't need to touch the gears. That is the approach my buddy used with his 67 Valiant with a 440, 4.10 gear. Short drag radials at the track, tall mud and snow tire for the drives, 10.90's. Another friend ran his 69 Dart with 408 W-2 engine the entire week with a 4.56 spool out back, and the same set of drag radials the full trip. 11 teens.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#2264711
03/07/17 02:42 AM
03/07/17 02:42 AM
Posts: 2,255 IL
furious70
IL
but he left you guys for dead everyday as he chased Ray out in the morning to make time for the 'leisurely' drive (or maybe to catch the blue plate special in the next city), right? :P
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Dart451]
#2264964
03/07/17 04:25 PM
03/07/17 04:25 PM
Posts: 667 IL
Dart451
IL
A couple pics as promised. Storming yesterday with high winds so only pics i have was ones he sent me. Already has a 440 with iron heads and mp590 cam
[Re: Dart451]
#2265127
03/07/17 09:11 PM
03/07/17 09:11 PM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
So you just bought that sexy thing and you're bringing it on Drag Week? Cool! That's like bringing Kate Upton to meet the church basement ladies!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: 67autocross]
#2265164
03/07/17 10:00 PM
03/07/17 10:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'll be running a 4.10 gear with a 518 OD trans... thats with a 416ci.. I can keep the street rpm at 2900 and run 75 mph... if I make it there
[Re: MR_P_BODY]
#2265609
03/08/17 03:09 PM
03/08/17 03:09 PM
Posts: 200 AB
Efidart
AB
I'll be running a 4.10 gear with a 518 OD trans... thats with a 416ci.. I can keep the street rpm at 2900 and run 75 mph... if I make it there Are you going to make it? Seems like you never have but sure talk about it a lot, is this year going to be the year?
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: Dart451]
#2265610
03/08/17 03:11 PM
03/08/17 03:11 PM
Posts: 200 AB
Efidart
AB
3.40 rear gear, 33" tall tires and a gear vendors OD = 15-1700 RPM cruising at 65-75MPH.
Most driving is between 45-65 MPH for 75% of the drive, go drive it on a hot day at 60 MPH and see what RPM it seems happiest with.
[Re: Dart451]
#2265926
03/09/17 12:19 AM
03/09/17 12:19 AM
Bad340fish
Tulsa OK
I don't see you having any issues with that lettering. Its not like your flying a sponsor's name on it. That is cool car!
