Crankcase evac ?
#2232570
01/11/17 11:49 PM
01/11/17 11:49 PM
Posts: 27 North Carolina
Juicedrinker
North Carolina
So what's everyone's opinion on crankcase evac kits on a pretty stought street/strip 440 or just run breathers on valve covers?
I’ll get it done one day....maybe....
Re: Crankcase evac ?
[Re: Juicedrinker]
#2232572
01/11/17 11:57 PM
01/11/17 11:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
So what's everyone's opinion on crankcase evac kits on a pretty stought street/strip 440 or just run breathers on valve covers? If you run muffs dont bother with evacs...reason why.. a evac will pull about 5"hg max so if you have muffs on the car every inch of back pressure the muffs have is 1" less that the evacs will pull and if your muffs are greater than 5"hg you will pressurize the crank case with exhaust
[Re: Juicedrinker]
#2232605
01/12/17 12:40 AM
01/12/17 12:40 AM
RapidRobert
Mister P, how/where do I measure the muffs (vac difference in/out?)
[Re: RapidRobert]
#2232663
01/12/17 02:51 AM
01/12/17 02:51 AM
MR_P_BODY
Mister P, how/where do I measure the muffs (vac difference in/out?) Tap in anywhere forward of the muffs... use a "HG gauge.. can use a psi gauge also
[Re: mopar dave]
#2232667
01/12/17 03:06 AM
01/12/17 03:06 AM
MR_P_BODY
what if you were to tap in at the end of the exhaust pipe after the muffs. would there be any vacuum there? No.. but your trying to measure the pressure before the muff.. that pressure is back pressure on the engine
[Re: StealthWedge67]
#2232670
01/12/17 03:12 AM
01/12/17 03:12 AM
MR_P_BODY
What are the merits of a PCV system at this application? They are great for cruise rpm.. no help at WOT
[Re: Juicedrinker]
#2232731
01/12/17 12:05 PM
01/12/17 12:05 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Pictured below is my preferred setup. Just -10 lines from each valve cover to a breather tank like you'd use for a vacuum pump setup. Works great.
I have a vacuum pump on my hemi and don't really care for it. Saw no change in performance. Wish I'd just used the same type of setup I have on my wedge motor.
[Re: BCFKody]
#2232761
01/12/17 12:53 PM
01/12/17 12:53 PM
an8sec70cuda
an8sec70Cuda...what type of oil rings are you running?? If low tension do you remember what the tension was rated at in lbs?? Thanks Had both in the hemi and saw no real difference. The current rings are low tension (18 lb).
[Re: an8sec70cuda]
#2232773
01/12/17 01:10 PM
01/12/17 01:10 PM
MR_P_BODY
I have a electric vac pump sitting on my bench that I was gonna put on the Rampage.. but I dont like vac pumps on a street car.. I run 2 breathers on it and no oil comes out of it.. but they are baffled
[Re: Juicedrinker]
#2232883
01/12/17 03:27 PM
01/12/17 03:27 PM
Juicedrinker
North Carolina
What would be better, just run breathers or the an line to a catch can like an8sec70cuda showed? Or about the same either way? My valve covers have no holes so I will have to drill them and have no baffles.
[Re: Juicedrinker]
#2232927
01/12/17 04:30 PM
01/12/17 04:30 PM
an8sec70cuda
What would be better, just run breathers or the an line to a catch can like an8sec70cuda showed? Or about the same either way? My valve covers have no holes so I will have to drill them and have no baffles. I like the lines and can b/c there's no leaks like you get w/ breathers on the valve covers. They'll drip oil everywhere.
[Re: cl440]
#2232943
01/12/17 04:51 PM
01/12/17 04:51 PM
MR_P_BODY
Does anyone make a catch can that can be used with header evacs?
The evacs could draw from the top of the can and the breather lines could enter somewhere midway up the can. This way it could still create vacuum but any oil would be left in the bottom of the can to be drained later?
Make sense? I use to make my own separator cans at work (I used them on fuel) but its simple... I put both lines in the top with different lengths of tube inside the can with the short one being the exit(to the engine in your case)
[Re: Juicedrinker]
#2233000
01/12/17 06:37 PM
01/12/17 06:37 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
Moroso make oil/air separators.
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Juicedrinker]
#2233004
01/12/17 06:43 PM
01/12/17 06:43 PM
Posts: 4,457 Washington
madscientist
Washington
I run a PCV and pan evacs. Before I bought my muffs I spent some time on the phone with them. They said as long as the pan evac is after the muff it will work. That's how I did it. The engine is sealed, the PCV pulls at idle and cruise, the PCV and pan evac at cruise and wide open.
