Re: Speedometer gear [Re: JohnH] #2233479
01/13/17 01:46 PM
01/13/17 01:46 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Ok, that will tell the tale. And as a side one tooth on the trans gear is worth about 2 MPH.
Re: Speedometer gear [Re: JohnH] #2233580
01/13/17 04:49 PM
01/13/17 04:49 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Hi way signs to measure distance or speed to calibrate speedometers today are as buggy whips and curb feelers.
Download a speedometer app or use a gps navigation system. See posting from several days back.
Re: Speedometer gear [Re: JohnH] #2233593
01/13/17 05:13 PM
01/13/17 05:13 PM
BDW Offline
BDW  Offline
Agreed, that app works great
Re: Speedometer gear [Re: JohnH] #2233594
01/13/17 05:16 PM
01/13/17 05:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Hiway signs work just fine if you haven't spent the big bucks for a smart phone.
Re: Speedometer gear [Re: stumpy] #2233682
01/13/17 07:47 PM
01/13/17 07:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In my state the painted stripes next to the mile markers are dead accurate...the airborne cops use the stripes to issue speeding tickets so they have to be accurate.
Re: Speedometer gear [Re: stumpy] #2233835
01/14/17 12:03 AM
01/14/17 12:03 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
For the price of a tank of fuel there are millions of smart phones for sale. Obama even gives them away.
Many highways in Calyfornua no longer have mile markers.
Before smart phones, I too used mile markers and a stop watch, that cost me more than a used smart phone costs today. The smart phone has proven more convenient for me and accurate and I ain't required to find no highway to check my speedo or odometer.
Could help OP with his issue.
I recently went thru a speedo accuracy issue with wife's 55 T Bird in which I had swapped in an AOD 4 speed auto transmission. I not only had to sort out mph speedo, but too an odometer accuracy problem. Could have done it with mile markers and a stop watch,,,,but would have wasted a few additional hours doing so over using this app.
60 mph, how long to go 1 mile=
120 mph, how long to go 1 mile=
90 mph, how long to go 1 mile=
Re: Speedometer gear [Re: JohnH] #2233866
01/14/17 01:28 AM
01/14/17 01:28 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
To check the speedo by mile markers you don't need a stop watch. Just see if the odometer goes one mile from marker to marker. Just do it during normal driving takes no extra time at all. Don't make it seem harder than it is. Yes your app will do it too but, for those of us that don't need or care for the fancy phone and apps, we can still do it the quick old fashion way. shruggy
Re: Speedometer gear [Re: JohnH] #2233900
01/14/17 04:16 AM
01/14/17 04:16 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
As an ex--fireman for the Chicago, Burlington and Quincy Railroad on the head locomotives of very high speed passenger trains such as the California Zephyr as a young man, trains sometimes running over 100 mph(speed limit 87 mph) we were always aware of our speeds.
Using either our RR certified pocket watches(or just introduced in the early 60's, Bulova Acutron wristwatches), we(Engineer or Fireman) were always train speed aware, and often would time our trains using mileposts and watches to check out the accuracy of the diesel locomotive speedometers, as accuracy was paramount.
Using this primitive technology, we would be close enough for government work,,,however if eyeballing your watch or the mile post you always were subject to a 'fudge' factor of several mph being common.
Using modern technology utilizing GPS either via a smart phone app or a Garmin type navigation device you are dead nuts on,,,,and far simpler. Calculate the answers to my 3 questions on mph and get back to me for further information, most who attempt will not have the correct answers.
It is impossible to accurately determine looking at an odometer that when the 10th mile indicator is exactly the same as it was when you started you measurement, however 5 or 10 mile measurement average will dial it in more accurately.
My point being that a GPS device is mandatory if you wish indisputable accuracy, if government work standards are sufficient and you have the time,,,mileposts and wristwatches will certainly do the job.
As for me I would prefer to have purchased and installed the correct speedometer gear on the first attempt.
The reason for suggesting to OP that a GPS device may help him in his quest.
The purpose of this forum is to help our fellow members in offering up opinions,,,,as to the most expeditious solution to problem that is presented
When I proposed a smart phone app to perhaps help him out, never occurred to me thst one should first ax if he had access to a smart phone.
Tough Crowd!
Re: Speedometer gear [Re: Sxrxrnr] #2233957
01/14/17 12:15 PM
01/14/17 12:15 PM
Tough Crowd!
We're the best. yes the mile markers are as accurate as an non electronic system can be but agreed I would borrow a smart phone or something similar. I catch Hell for this. I unhook the wire to disable the ringer at night.
Re: Speedometer gear [Re: JohnH] #2236845
01/18/17 05:51 PM
01/18/17 05:51 PM
Stevensville, ON
Frank Raso Offline
Frank Raso  Offline
Stevensville, ON
You can calculate exactly what speedometer pinion gear you need if you know the tire size and axle gears. I went through this exercise when I upgraded my 65 Barracuda to LBP wheels and have a write-up about it.
Tire Upgrades
What size tires do you have on the back?
