Re: gettin spark for a second
[Re: mopar muscle7271]
#2231246
01/10/17 12:14 AM
01/10/17 12:14 AM
RapidRobert
Progress! looking good. EDIT I'd get the new ECU in & see what happens. Standard Motor Products used to make a good American made parts house ECU but it is made in China now (iirc it is $25).
#2231879
01/10/17 10:12 PM
01/10/17 10:12 PM
RapidRobert
Lets do this, hook everything back up & hold the coil secondary wire (dist end) 1/4" away from the intake (ground) and with the dist pickup zigzag pull apart connector seperated, drag the male tip end of the body half across the intake surface (ground) & see if the coil wire sparks (do it with key on and with key held to start with the yellow wire terminal pulled off of the "ign" terminal on the starter relay). then reconnect the zigzag connector and remove any and all wires off of the dist neg primary post (might just be the one) and with a jumper wire connected to the coil terminal itself (not to the ring terminal you removed from it), tap tap the other alligator clip on the other end of the jumper to the intake & same thing see if the coil wire sparks (with key on & key held to crank). Holler back.
#2232053
01/11/17 01:29 AM
01/11/17 01:29 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If the coil sparks it's not the coil, though I did have a coil that would intermittently fail when it got hot, but it failed in either mode. It would work when cooled off. Took awhile to sort it out but I got it.
Eventually you will have to break out a meter and find out what is going on.
#2232082
01/11/17 02:37 AM
01/11/17 02:37 AM
Posts: 468 las vegas,nv
mopar muscle7271
las vegas,nv
I have a meter and will test the coil and see what the reading says. It was hot when the last time i tried starting it.
[Re: OzHemi]
#2232094
01/11/17 02:56 AM
01/11/17 02:56 AM
RapidRobert
Neat tool, What is the gap when it gets to "super"? it would be a "cold" test. EDIT now I see the numbers for the gap
#2232103
01/11/17 03:43 AM
01/11/17 03:43 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Are you saying it sparks once when you turn the key off ? As it sounded like thats what you were saying at first ? No spark while cranking but a spark when the key is turned off ? I just want to be sure just what it is doing. Ron
#2232116
01/11/17 04:17 AM
01/11/17 04:17 AM
mopar muscle7271
las vegas,nv
I turn the key on i have spark.when i crank the key the over to start it,i loose all spark.when i let go of key i have alittle spark again.
[Re: Kern Dog]
#2232979
01/12/17 05:53 PM
01/12/17 05:53 PM
mopar muscle7271
las vegas,nv
Ok i replaced the distributor last year in it,maybe its bad again. I have replaced all those items.would fouled up spark plugs cause a no start as well?
[Re: OzHemi]
#2233039
01/12/17 07:24 PM
01/12/17 07:24 PM
RapidRobert
I don't use it often, but still a kind of cool thing to have around.
Instructions on it, if you were curious..
Yeah I see the heat setting on it.
#2233041
01/12/17 07:29 PM
01/12/17 07:29 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Ok i replaced the distributor last year in it,maybe its bad again. I have replaced all those items.would fouled up spark plugs cause a no start as well? I think fouled plugs may make it harder to start, misfiring at all speeds but not a "no-start" condition unless the electrodes are burned off or there are so many deposits in there that no gap remains between the tip and electrode.
