Re: At what point is 4130 worth it??
[Re: DemonDust]
#2230403
01/08/17 09:53 PM
01/08/17 09:53 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
It wont meet 25.5 with steel.
[Re: TRENDZ]
#2230413
01/08/17 10:03 PM
01/08/17 10:03 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
It wont meet 25.5 with steel. Good to know. I'm sure it states this in the book along with plenty of other things. I guess I know my answer. 4130 it is!
[Re: DemonDust]
#2230455
01/08/17 11:01 PM
01/08/17 11:01 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Yup, it's a no Brainer if your rebuilding
[Re: FastmOp]
#2230483
01/08/17 11:41 PM
01/08/17 11:41 PM
Posts: 6,149 Melbourne , Australia
LA360
I wouldn't bother with Mild Steel personally. I have a few of the cage regs scanned, can't remember which ones I ended up with.
Alan Jones
[Re: TRENDZ]
#2230487
01/08/17 11:45 PM
01/08/17 11:45 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
It wont meet 25.5 with steel. Since when??
[Re: DemonDust]
#2230508
01/09/17 12:14 AM
01/09/17 12:14 AM
Posts: 4,210 New York
polyspheric
New York
It doesn't matter, does it?
Boffin Emeritus
[Re: GTS340]
#2230511
01/09/17 12:18 AM
01/09/17 12:18 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
It wont meet 25.5 with steel. Since when?? No cage with a mild steel hoop will cert quicker than 8.50. A 25.5 cert is good to 7.50
[Re: DemonDust]
#2230573
01/09/17 01:19 AM
01/09/17 01:19 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
If your going bracket racing, why spend the extra $ on a CM cage? The weight savings of CM will not win you any races. Nascar uses mild steel, so it can be built strong and safe. Now if you're racing heads up, then the weight savings of CM makes it a necessity.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: DemonDust]
#2230602
01/09/17 02:20 AM
01/09/17 02:20 AM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A roll bar just to go 11s or mid-high 10s? MIG and MS, maybe the right choice for some. But it would get cut out and CM used for any upgrades were it up to me. Anything that will need a tag of any kind, CM.
[Re: John Burdine]
#2230642
01/09/17 05:28 AM
01/09/17 05:28 AM
Monte_Smith
North Alabama
was this a rule change over the last couple years, I thought 25.5 (7.50) could be mild, moly, or a mix. My car is a mix, the main hoop being mild steel, it certed a few years ago 25.5. You are correct, it can be a mix at 25.5. There are so many specs now, hard to keep them straight
