Re: Which T-bars 4 mostly street, occassional strip Hemi B-body
[Re: topside]
#2229860
01/08/17 02:30 AM
01/08/17 02:30 AM
Posts: 1,805 ky hills
thehemikid
ky hills
My combo fwiw,...
70 RR 475" Hemi iron block, Al head, tti 2&1/8", 4spd. .920 bars, & Bilstiens all around.
Two different friends, one with a 69 Hemi 4spd Superbee, other with a 70 V code 4spd Superbee, have both ridden in mine and commented "it rides like a Cadillac".
[Re: fullmetaljacket]
#2230056
01/08/17 03:10 PM
01/08/17 03:10 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I have the Mopar 0.96" T-bar on my Charger and Coronet. They have a good ride on the street. The Charger has the old KYB gas shocks, and PST sway bars, poly bushings, and stiffer rear springs. The ride is about like most new cars, maybe a bit on the firm side, but not harsh. The Coronet Convertible (a bit heavier than the Charger) has the RCD Bilstein shocks, Mopar replacement HP rear springs, and stock R/T front sway bar. The car rides smoother, almost soft, most likely the difference in shocks and having rubber bushings. It could use larger sway bars in my opinion. The 0.96" bar is not great for drag racing. If you want the front end to lift at the track, the smaller bars would be better. Also, I think the 0.96" bar is the largest that is still indexed Left and Right? I think the 1" and larger bars have the same index and can be used on either side of the car?
#2230067
01/08/17 03:23 PM
01/08/17 03:23 PM
Posts: 200 Colorado
Bob J
Colorado
The Hotchkis 1.03 bars that I have are labeled L and R. I haven't installed them yet maybe next weekend if I can get the K frame ready and painted today I can install them next weekend. I also have a set of 0.96 T bars new in the box and the stock 0.92 set. I always thought that the stock bars were to soft.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
#2230646
01/09/17 05:54 AM
01/09/17 05:54 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I went with the 1.15 bars from bergman, will probably go with the viking shocks down th road. tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
