Which T-bars 4 mostly street, occassional strip Hemi B-body
#2228997
01/06/17 11:44 PM
01/06/17 11:44 PM
fullmetaljacket
For a friend that is building a 68" Coronet 4 speed car that will see mostly street. He wants to know which size bars and brands (Mopar, Hutchinson, Firm Feel) should he use with this Hemi/stick combination. Car will see some strip tease action but mostly tooling around the town on weekends. He has KYB front shocks and using HD leaf springs out back. Don't ask! I don't know the weight as of yet.
Re: Which bars 4 a mostly street, occassional strip Hemi B-body
[Re: 71birdJ68]
#2229022
01/07/17 12:05 AM
01/07/17 12:05 AM
fullmetaljacket
All iron, heads, iron bell housing, 833 new process iron box. But what does that have to do with what Torsion bars to use if I may ask? Is it front end weight?
Re: Which T-bars 4 mostly street, occassional strip Hemi B-body
[Re: fullmetaljacket]
#2229078
01/07/17 01:10 AM
01/07/17 01:10 AM
Posts: 22,782 Bitopia
jcc
Bitopia
For a friend that is building a 68" Coronet 4 speed car that will see mostly street. He wants to know which size bars and brands (Mopar, Hutchinson, Firm Feel) should he use with this Hemi/stick combination. Car will see some strip tease action but mostly tooling around the town on weekends. He has KYB front shocks and using HD leaf springs out back. Don't ask! I don't know the weight as of yet. Based on above info, anything over 1" dia for starts, a skinny bar (.89") IMO, will not help enough at the strip vs the wallow handling when driven mostly on the stree,t trying not to wrap it around a light pole.
[Re: jcc]
#2229120
01/07/17 02:17 AM
01/07/17 02:17 AM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
My year round daily driver in Oregon (lots of twisty roads) has .890 bars, all iron bog block, 5.5"rims and it rides nice and comfy. If I want something that rides like a new 300C I take our 300C SRT8 to town.
.890 bars are stock 383 bars IIRC. The car rides nice and does not try to imitate a Ferrari by letting you know the condition of the roads crack by crack. Nobody has ever ridden in it and commented about the harsh ride either.
In contrast my year round previous daily driver when we lived in the snowy mountains/high desert of Oregon was a '66 Charger (iron 440, 1.08" t-bars, front/rear sway bars, 8" wheels). It was an awesome handing 4300 lb car but again...every crack in the road was evident. Every passenger that ever road in the car other than my wife commented on the "ride" or lack thereof. Don't get wrong, we drove it all over the Western states in all types of weather and loved every minute. The car would four wheel drift with precision, ever with studded tires in the ice lol.
My point in all of that rambling is that if the driver of said car is not into having their dental work jarred I'd steer clear of t-bars over 1.04ish, low profile tires and polyurethane lower control arm bushings. Oh, and KYB shocks as said. They are the Rancho 5000 of muscle cars.
![Name: 100_6786 (Large).JPG
ID: 269000 100_6786 (Large).JPG](/ubbthreads/ubbthreads.php/ubb/download/Number/269000/filename/100_6786 (Large).JPG)
[Re: Jeremiah]
#2229138
01/07/17 02:59 AM
01/07/17 02:59 AM
Posts: 3,397 Pa
Hot 340
Pa
In contrast my year round previous daily driver when we lived in the snowy mountains/high desert of Oregon was a '66 Charger (iron 440, 1.08" t-bars, front/rear sway bars, 8" wheels). It was an awesome handing 4300 lb car but again...every crack in the road was evident. Every passenger that ever road in the car other than my wife commented on the "ride" or lack thereof..
You have to buy good shocks or youll get a rough ride with big bars. What shocks did you use in this set up?
#2229143
01/07/17 03:08 AM
01/07/17 03:08 AM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I see a couple of mentions here about ".890" bars. I found listings for b/e bodies of .880 and .900...... Didn't see any for .890.
I don't think I'm knew there was a .900 bar, I just thought there was the 6 cyl bar(.860), v8 bar(.880), 440/hemi bar(.920). Apparently there is also the .900 bar(383-4bbl). Guess I'll have to check the numbers on mine to see which they are. In theory, if they're original, they should be .900 since it's a 383-4bbl car. I thought I measured them at something less than .900 at some point.
#2229371
01/07/17 03:10 PM
01/07/17 03:10 PM
fast68plymouth
So. Burlington, Vt.
I checked the bars that came out of my car.....I'm not certain they are the original bars though. 776/777, .880 ......... The std v8 bar, not the. 383-4bbl bars. I guess if it didn't come with HD suspension, for 68 it would just get the std v8 bars.
[Re: fast68plymouth]
#2229386
01/07/17 03:34 PM
01/07/17 03:34 PM
Jeremiah
Rogue River, OR
I don't think I'm knew there was a .900 bar, I just thought there was the 6 cyl bar(.860), v8 bar(.880), 440/hemi bar(.920). Apparently there is also the .900 bar(383-4bbl). Guess I'll have to check the numbers on mine to see which they are. In theory, if they're original, they should be .900 since it's a 383-4bbl car. I thought I measured them at something less than .900 at some point. All three of my original 383-4 cars have bars that measure .890. Probably .880 w/ .010 of black paint. I'll have to double check my '66 Coronet w/ HD suspension (on f-tag IIRC) and see if they are closer to .900 OD. Come to think of it the 383-4 A/C equipped convertible should have HD suspension too the way it was optioned. I'll check that one too.
[Re: Hot 340]
#2229394
01/07/17 03:40 PM
01/07/17 03:40 PM
Jeremiah
Rogue River, OR
You have to buy good shocks or youll get a rough ride with big bars. What shocks did you use in this set up? Koni's for a while. Then for a short period some QA1's I was going to replace them with the Bilstiens (QA1's were destined for other Charger) but sold the car when we moved. Are you finished with your questioning counselor? lol
[Re: Jeremiah]
#2229406
01/07/17 03:57 PM
01/07/17 03:57 PM
Posts: 3,397 Pa
Hot 340
Pa
It was only one question. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Defense may cross examine.
[Re: polyspheric]
#2229655
01/07/17 08:39 PM
01/07/17 08:39 PM
jcc
Bitopia
To interpret comparisons between different bars: the "stiffness" (resistance to wheel travel) is definitely not linear. It's much closer to proportionate to the 4th power (^4) of the actual diameter, so subtracting .010" for paint etc. may be useful. Here are some common sizes with .010" deducted. To compare for the rate, divide the right column numbers. E.g., a .940" bar is about 43% stiffer than an .860" bar, etc. This suggests that even a single interval swap (.900" to .920") may help. .860": .522 .880": .573 .900": .627 .920": .686 .940": .748 .960": .815 .980": .885 1.000": .961 1.020": 1.041 1.040": 1.126 Without sugar coating: 1. you are stating the obvious 2. Op asked what he should use, not if a larger size would "help" 3. There are numerous threads in the Handling forum here that have pretty well supported the agonizing slow awareness/consenus that our mopars have been undersprung for decades, and a single step increase from OEM on a TB, without reason, is just plane wasting money
