Re: Suggestions for Hellcat Supercharger Bypass
[Re: hudsonhornet7x]
#2242517
01/27/17 10:40 PM
01/27/17 10:40 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
RPM switch set to close the bypass at somewhere above 2200 rpm, and a pressure valve plumbed from the pressure side to bleed off excess pressure back to the inlet side of the intake? The extra pressure sensitive bypass may be needed at some point in the rpm range to stay below your chosen boost level.
[Re: GoodysGotaCuda]
#2643148
04/09/19 10:13 AM
04/09/19 10:13 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
IIRC your motor is built a little better than stock correct? I think a Whipple, or Magnuson would be a more cost effective solution that would work with your EFI without any additions.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2643872
04/10/19 09:56 PM
04/10/19 09:56 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
IIRC your motor is built a little better than stock correct? I think a Whipple, or Magnuson would be a more cost effective solution that would work with your EFI without any additions. I'm investigating both options. The pre-eagle 5.7L i have is stock with the only modifications being an upgraded cam, opened ring gaps [for this very reason] and headers. I figure a whipple would run about $5-6k, Hellcat setup is looking around $8500-$9000 if I were to sell the 5.7L off for a couple of bucks and add another 80-100whp I figure. The bragging rights that go along with owning a "Hellcat Cuda" is also appealing.
[Re: Mopar_Rich]
#2644295
04/12/19 08:12 AM
04/12/19 08:12 AM
Posts: 1,543 USA
hudsonhornet7x
USA
I have done several of these using the Holley Dominator ECU. I replaced the DBW bypass with a vacuum operated one that I got from Magnuson. Bolted right in. efiexpert.com
Rich, Thank you for that information. I searched on their site. Do you have a part number handy?
#2698755
09/18/19 04:36 PM
09/18/19 04:36 PM
Posts: 1 VA
Hemiquest
VA
Another option is www.SmoothBoost.com they have a plug and play controller that runs the hellcat valve regardless of what efi system your using
[Re: Hemiquest]
#2706137
10/12/19 10:12 AM
10/12/19 10:12 AM
Posts: 6,427 S.E. Missouri
AeroMonte
S.E. Missouri
Another option is www.SmoothBoost.com they have a plug and play controller that runs the hellcat valve regardless of what efi system your using This is what I'm using on our Hellcat swap. Just got the car running but it will be awhile before it can be street tested. I have a Holley Dominator EFI
