Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2235707
01/16/17 10:57 PM
01/16/17 10:57 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2242517
01/27/17 09:40 PM
01/27/17 09:40 PM
gregsdart Offline
gregsdart  Offline
RPM switch set to close the bypass at somewhere above 2200 rpm, and a pressure valve plumbed from the pressure side to bleed off excess pressure back to the inlet side of the intake? The extra pressure sensitive bypass may be needed at some point in the rpm range to stay below your chosen boost level.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2243515
01/29/17 05:40 PM
01/29/17 05:40 PM
USA
hudsonhornet7x Offline OP
USA
Thanks everyone for the advice- I will let you all know what I do and how it works.
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2642495
04/07/19 09:10 PM
04/07/19 09:10 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Bumping an old thread - I have a Megasquirt Gold Box/EFI Source, anyone have an update on how that wires up and works out?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Suggestions for Hellcat Supercharger Bypass [Re: GoodysGotaCuda] #2642831
04/08/19 03:32 PM
04/08/19 03:32 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
FYI, you only want the bypass closed at WOT or close to it. Otherwise you will have problems in the long run. Lots of guys burning them up because they think disabling the bypass is a good idea...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Suggestions for Hellcat Supercharger Bypass [Re: GoodysGotaCuda] #2643148
04/09/19 09:13 AM
04/09/19 09:13 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
IIRC your motor is built a little better than stock correct? I think a Whipple, or Magnuson would be a more cost effective solution that would work with your EFI without any additions.
68 Barracuda Formula S 340
Re: Suggestions for Hellcat Supercharger Bypass [Re: Bad340fish] #2643872
04/10/19 08:56 PM
04/10/19 08:56 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'm investigating both options. The pre-eagle 5.7L i have is stock with the only modifications being an upgraded cam, opened ring gaps [for this very reason] and headers.
I figure a whipple would run about $5-6k, Hellcat setup is looking around $8500-$9000 if I were to sell the 5.7L off for a couple of bucks and add another 80-100whp I figure. The bragging rights that go along with owning a "Hellcat Cuda" is also appealing. work
2020 RAM 1500
Re: Suggestions for Hellcat Supercharger Bypass [Re: GoodysGotaCuda] #2644161
04/11/19 06:57 PM
04/11/19 06:57 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I have done several of these using the Holley Dominator ECU. I replaced the DBW bypass with a vacuum operated one that I got from Magnuson. Bolted right in.
efiexpert.com
Re: Suggestions for Hellcat Supercharger Bypass [Re: Mopar_Rich] #2644295
04/12/19 07:12 AM
04/12/19 07:12 AM
USA
USA
efiexpert.com
Rich,
Thank you for that information. I searched on their site. Do you have a part number handy?
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2698755
09/18/19 03:36 PM
09/18/19 03:36 PM
VA
Hemiquest Offline
Hemiquest  Offline
VA
Another option is www.SmoothBoost.com they have a plug and play controller that runs the hellcat valve regardless of what efi system your using
Re: Suggestions for Hellcat Supercharger Bypass [Re: Hemiquest] #2698804
09/18/19 08:50 PM
09/18/19 08:50 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
EFI source gold box will run the bypass without any extra stuff added on.
SDG Motorsports
Re: Suggestions for Hellcat Supercharger Bypass [Re: Hemiquest] #2706137
10/12/19 09:12 AM
10/12/19 09:12 AM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
This is what I'm using on our Hellcat swap. Just got the car running but it will be awhile before it can be street tested. I have a Holley Dominator EFI
