Re: Suggestions for Hellcat Supercharger Bypass
[Re: hudsonhornet7x]
#2228728
01/06/17 05:22 PM
01/06/17 05:22 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Could be tricky, Efisource was saying they had one running. Wonder why Mopar doesn't offer a plug and play for these as well.
Mopar to the bone!!!
#2229157
01/07/17 03:59 AM
01/07/17 03:59 AM
72Swinger
Nebraska
Or get the 4.5 Whipple that bolts to the Hellcat engines.
#2229182
01/07/17 09:52 AM
01/07/17 09:52 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Are you keeping the factory EFI system? I know a guy who's tuning them now and getting noticeable gains over stock. He started out doing the 5.2/5.9 magnum stuff in Dakotas using SCT, but is now tuning all the hemi stuff as well as viper v10 stuff.
Flyinryan performance. Look him up on FB or his website.
**Photobucket sucks**
#2229934
01/08/17 12:10 PM
01/08/17 12:10 PM
Posts: 68 Southern Michigan
mike_coates
Southern Michigan
Why are you wanting to get rid of the electronic bypass? If it is for performance gains, but still be streetable, you would be better off to keep it and get a tune to achieve what you want. The electronic bypass is much better from an overall standpoint than the vacuum bypass. The vacuum bypass is like a rotary dial phone vs. an I phone. If you don't get the vacuum set up right or have a problem with it, you can cook you blower. The electronic is fail to open while the vacuum fails to close.
'70 Swinger 340 '91 Dakota '72 Challenger '05 Ram
#2229938
01/08/17 12:13 PM
01/08/17 12:13 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
The Electronic bypass is hard to manage without the proper computer, and since hellcat swaps are not just real common yet I am not sure who has the ability to run it properly.
I do know there was a shop out of a Florida that did a Hellcat swap on a 60s B body and was using Holley EFI. I saw this in the G3 Hemi Swap group on Facebook.
68 Barracuda Formula S 340
#2232256
01/11/17 01:26 PM
01/11/17 01:26 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I would stay with the electronic valve and use the Holley Dominator. You can easily configure an I/O based on MAP to open and close the valve.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: AlexP]
#2232583
01/12/17 12:15 AM
01/12/17 12:15 AM
Posts: 4,255 Canada
WO23Coronet
Canada
Why not just block the bypass off and let it act like the rest of the blowers out there? It causes them to overheat when you have little throttle opening
