Gear Vendor disengages after 2000 miles drive
#2227166
01/04/17 04:01 PM
01/04/17 04:01 PM
Posts: 48 the Netherlands
dutchrunner
the Netherlands
Hi Forum members . Have the GV now behind my John Cope CTR-4 for 2 years. Have had same issue for last 2 years. After driving a total of about 2000 miles the GV disengages by it self when activated on highway. It's not a temp problem. 2 years ago had issue first time. Changed fluids and cleaned filter. Problem gone. Now last year again same issue. Have momentary switch on Cheetah shifter and select on moment always above 50mp/h. Strange thing is that it's never first drive after winter of when cold or very hot. Always in august . 2016 and 2015. Have called GV tech line and have had very good test instructions but was wondering if anybody have had this also.
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
Re: Gear Vendor disengages after 2000 miles drive
[Re: dutchrunner]
#2227472
01/04/17 11:42 PM
01/04/17 11:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Are you running a relay on the circuit.. it sounds like the you have it hooked up to a switch... the solenoid could be drawing a bit too much causing heat.. if you turn it off then back on does it engage.. it wont have anything to do with the month
[Re: dutchrunner]
#2227512
01/05/17 12:25 AM
01/05/17 12:25 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Ok, back when I was looking at them, the switch was either on or off, that's it. Now, they have Much more complicated controls for them if needed, with there Own controller box . They can even tie in with your electric lockup vert,vac etc for more precise control of the gear vendor unit. How complicated is your setup. Now there can be Much more to consider then just the on off of the engagement solenoid.
[Re: dutchrunner]
#2227805
01/05/17 02:45 PM
01/05/17 02:45 PM
dutchrunner
the Netherlands
MrPbody , It's like the GV makes the oil dirty after about 2000 miles and this causes the GV to not have enough oil. When I stopped and let the oil cool for about 1 hour it didn't work. Drove for about 500 miles more and then it worked again for some days. After changing oil and cleaning filter the issue was gone for 3 moths till winter and first 5 months of next year. Then again the GV turned off every now and then. And stopped again after 400 miles.
Sport440 , The GV is 2 years old and besides "stock" set-up like in manual the only difference is the momentary switch on the Cheetah which is connected like the supplied footswitch.
Not really clear in my head if it's not the wear of GV , like the tech line said , why the issue is gone for 1 year if you change the oil and clean filter.
[Re: dogdays]
#2231037
01/09/17 08:01 PM
01/09/17 08:01 PM
Posts: 25,977 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It has an internal pump to compress a clutch pack for the overdrive to function. This clutch pack looks just like one in an automatic transmission. Uh-uh, it's a cone clutch.
[Re: Triggerfish]
#2231705
01/10/17 04:36 PM
01/10/17 04:36 PM
dutchrunner
the Netherlands
Dogdays : Thanks for the input. Heat should not be issue as it has only happened on highway and not after stopped or slow driving. And the heat does not change after the 2000 miles. Had even higher temp outside and GV still worked. It's deffinitly a distance/time related issue.
Triggerfish : Have called tech GV and they said it's power issue . Something like battery to low or too high. Have changed 1 wire alternator for other type last winter and issue did not change. Perhaps some issue like leaking pressure and this causes slippage like bands in 727 but then in GV and this makes oil dirty.
Tech GV have given me some tests to do and need to get back to them after this BS weather is gone in The Netherlands and I can give the Hemi a nice beating.
[Re: dutchrunner]
#2233145
01/12/17 10:37 PM
01/12/17 10:37 PM
Posts: 701 Southern Maryland
preddy
Southern Maryland
Dutchrunner, I could be wrong but I don't think it is a momentary switch. It is either off or on and the GV "remembers" whatever the last value was. Turboaction sells a GV switch for their shifters (I have one) that may work for you. Could your switch be bad? I experienced something like you are a while back. It turned out to be one of the connections to their controller had worked itself loose from the G forces from hard launches. I reset them all and it's been fine since.
[Re: dutchrunner]
#2233584
01/13/17 05:00 PM
01/13/17 05:00 PM
dutchrunner
the Netherlands
Preddy , Thanks for input. Above could be possible but still does not answer questions why GV works again okay after oil/filter cleaning.
GV Techkies said Volts issue but why only happening after long driving months and is gone after new oil. In my point of view it's like loose band in 727 but then in GV unit. Slip causes material to make oil dirty and clogs filter and GV switches of.
