Re: paint job on a budget!?
#22250
03/21/06 07:04 PM
03/21/06 07:04 PM
Posts: 1,614 Littleton, NC
KingMopar
Littleton, NC
Just "curing" wise.....I just shot some Rustolium Satin on my dash, ashtray and glovebox. The Satin lists Acetone as it's thinner. Each part was sandblasted, metal prepped, wiped with Prep-Sol, dryed and first a level of thin green etching done, light resand, then shot. My first piece was the glovebox, and noticed the paint was too thick even thinned to the Rustolium's recommended 15%(It showed the same exact "orange peel" effect, as the gentlemen showed above--though he was rolling, and this was Satin, not gloss!) Upon adding thinning it farther, round 10%, it flowed like glass on the other parts, self leveled, with several "sprayed" coats(and I tried to help level the glovebox with more thinned coats--bad mistake)
The dash and ashtry finished, I concentrated on the glovebox, which had sat 3 days. Wet sanded with 600 to get the orange peel/sag out....slight wipe with Prepsol getting ready for the shoot, and the paint wiped completely off..and the rest could be scratched via fingernail-aka, still soft.(sound familiar...and I'm a shooter, not a roller)
So..in a nutshell, either shooting or rolling, the paint really needs to be on the thinner side of life to prevent the orange peel effect-- and any sanding breaks the upper crust of where the paint has hardened. For full, full boned cure, me also thinks far over a month is gonna be the norm, for the fingernail test--especially for mineral spirits which will take far longer to gas off.
We did parts(but shot) on my Bud's Camaro some years back with Rustolium, inner fenders, etc...and properly cured, tough as nails--and he washes the poop outta it.
So....Keep on Roll'n....interesting thread.
#22251
03/21/06 08:25 PM
03/21/06 08:25 PM
how bad is the red paint underneath all of the artwork? Did they just brush that on too? If so, you've got plenty of sanding to do I would think, if you are shooting for a smooth finish that is. I was gonna suggest chemical stripping, but that would probably be a toxic nightmare given how much has to come off. I've done small sections before, but never a whole car. That stuff really works, but it is really nasty, to your skin, to the air (vapors are brutal), and the mess it makes getting all the paint off. It might take longer, but I'd stay with the sanding.
#22252
03/21/06 09:45 PM
03/21/06 09:45 PM
Well no, it looks like legit car redpaint but they did a HORRIBLE job, it like dripped on to the skirt oversprayed on the emblem, might even be a rattle car job, but its very thick, the art work is thick too :S But yea, gonna take me a while to sand all that. Not in a rush anyways, i dont have a garage to paint it to begin with, so i'm trying to arrange a garage at my friends.
PS: Its this point i feel like "WTF am i doing! "
#22253
03/22/06 06:03 PM
03/22/06 06:03 PM
Well got it to be pretty smooth now with 65grit then 120 i think prolly will do one more with 300 later.
[Re: gdub]
#22255
03/23/06 05:07 PM
03/23/06 05:07 PM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
I've been reading this thread the last couple of days and it looks like the answer for painting my truck. My question is will bondo work over the rustoleum primer? My truck is bare metal and in need of a fair amount of filler. Can I prime it and then bondo or do I bondo and then prime?
Thanks in advance, Gary
sand the metal area to be repaired with 60 grit to give the bondo something to bond to, then use the bondo, then finish it with 400-600 grit then go to primer, or if you wish straight to paint.
[Re: 69chargeryeehaa]
#22256
03/23/06 06:14 PM
03/23/06 06:14 PM
how does the paint adhere to plastics? I have plastic bumpers and was also thinking about using it on hard interior parts. Sweet stuff!
#22257
03/23/06 09:52 PM
03/23/06 09:52 PM
How long should I wait before waxing this thing? I would like to have a couple of layers of wax to protect everything, but I don't want to put it on before the paint has cured...or does it matter?
#22258
03/23/06 10:21 PM
03/23/06 10:21 PM
GOOD QUESTION!!!! I've been considering that for my Miata, which has been recieving a daily dose of sandblasting because of all the highway construction underway around here. The plastic front bumper is a now a pitted mess from all the stones, sand and everything else. I haven't even considered doing anything to it until all the road work is done, but it shouldn't be too much longer.
Having a little bit of experience with this paint so far, I'm optomistic that it will adhere to plastic bumpers well, but have no concrete evidence yet. I just bought a new car for my daughter tonight and will have her old POS Ford Escort toclean up for resale. I had to replace the front bumper and fender on it last year (courtesy of my son!) and just did a quickie rattle can spray job on it. It's white, and I just happen to have some white Rustoleum left over from Project Beer Fridge. If I try it out (even on a small section) I 'll make sure to post some results. The Escort bumper, although plastic, is significantly stiffer than the Miata bumper. Could be interesting. Anyone try this?
#22259
03/23/06 11:05 PM
03/23/06 11:05 PM
I have not had any problem painting the plastic bumpers in my car. The paint adhesion is the same than the metal or painted surfaces.
#22260
03/23/06 11:10 PM
03/23/06 11:10 PM
Sweeeeeeet...
[Re: Exit1965]
#22262
03/24/06 12:39 AM
03/24/06 12:39 AM
Question: When wetsanding between the coats, how do you wash/clean the wetsanded residue off? Water? mineral spirits? or SOAP WATER? Thanks, Also would it matter if i painted outside, since i do not have a garage? Will dust and dirt stick to the paint or is it thin enough (considering it has been thinned such as the directions state) that it will dry fast enough and not catching alot of dust/dirt. Also, lol how long does the coats take to dry, say i get the first coat on in the morning. 4-5hours?
#22263
03/24/06 03:42 AM
03/24/06 03:42 AM
Exit1965, I'm talking about real wax, Carnuba or whatever your preference. Just like any other car, I wanna keep the paint safe hehe bakuryu, You need to wash the residue off. I just wipe it down with a clean rag and water...let it dry...then wipe everything with mineral spirits again to make sure it's clean. I do get some dust sitcking to the paint (i'm painting in my garage), but it's easy to sand out when you are wetsanding. each coat of paint takes about 90 minutes to harden over and about 4hours to dry enough to wetsand from my experience. I usually put a coat of paint on in the morning then another in the evening and wetsand the next morning.
#22264
03/24/06 08:17 AM
03/24/06 08:17 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Exit1965,
bakuryu,
could try denatured alcohol instead of mineral spirits, too. it's mild, so it shouldn't take the paint off like laquer thinner would, and it has a really short flash time, so it would dry much quicker than the mineral spirits. and alcohol will absorb any moisture left over from wiping it down with water.
[Re: patrick]
#22265
03/24/06 10:25 AM
03/24/06 10:25 AM
Well like the directions suggest, you have to do 2coats then wetsand, the 2 coats and wetsand, the 2 coats and polish. Well when doing the first two coats should i just do the second coat of the first set, after the 90minutes of it hardening or after the complete 4hours, I know these seem to be small stupid questions, but i dont want to get any thing wrong.
[Re: Exit1965]
#22266
03/24/06 10:26 AM
03/24/06 10:26 AM
69chargeryeehaa
toronto canada
I don't have an answer - but what kind of wax are you talking about? It is different than the cheap turtle wax polish you already applied (or did you?). If you're talking the polish, it can be applied right after the final wetsand- but wax maybe a different animal.. 69charger has probably done it, charger, where art thou?
i've allways waxed right after the final polish, never had issues, and the paint on both my cars is rock hard, but i never intentionally tried a scratch test on my cars, only reciently when the whole scratch debate started did i test the charger, which was painted 5 months ago.
as for the wetsanding, i clean the residue off while it's still wet, just after wetsanding, i use a shammy and a bucket of clean water, it's alot eaiser to clean while wet, then just before painting, i clean with mineral spirits, and then use a standard autobody "tach cloth" which is a sticky cheese cloth rag you can get at any auto parts store for $1, before i paint each pannel/area i use the tack cloth, and have virtually no dust/dirt issues.
as for painting over plastic bumpers, i've never had any problems with any parts i've painted, but like any paint if it's flexed enough it will crack. i've painted my 85 CRX bumpers, and my old 86 mustang gt, no issues with the paint sticking or cracking. the front fenders on the charger are fiberglass, i've popped them in and out while working on the engine by accident and nothing happened to the paint, in the sun when those fiberglass fenders heat up they get about 1/4" longer and expand from the heat, no issues.
#22267
03/24/06 10:32 AM
03/24/06 10:32 AM
69chargeryeehaa
toronto canada
lets say you paint at 10am, wait until at least 7pm to do the next coat, if you do it too early like 90 mins, the new paint might make the old paint soft again. i've allways painted at 10 am or so, then 7pm, then next morning at 8am i'd start wetsanding, clean the whole car with a shamy, then mineral spirits, then tack cloth the area just before painting. this all depends on weather conditions, the hotter the better, but high humidity is your enemy, and you should wait longer. put fans on the car to accelerate the process, try to wetsand a small test area, if it wetsands fine, then your ready to do another coat, if it's still wet, and balls up when wetsanding let dry more.
#22269
03/24/06 11:48 AM
03/24/06 11:48 AM
Thanks for the replies guys! Looks like I'll have my delivery of tremclad on sunday so I'm hoping early next week the process will begin.
