Re: Can i reuse my flex plate [Re: Cab_Burge] #2227531
01/05/17 12:52 AM
01/05/17 12:52 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Never broke a b&m
New parts are not preventive maintenance. Flexplates break because of tire shake or vibration. Best way ti prevent flexplate problems is by checking crank centerline. It's a pita with a stock case due to having to remove pump. But, then you know.
Re: Can i reuse my flex plate [Re: mopar dave] #2229979
01/08/17 01:04 PM
01/08/17 01:04 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I have 3 cracked B&M round flex plates from about 6 years ago. I switched to the mopar sfi plate. They haven't cracked since.
Mine is an 8 bolt crank. The B&M flexplates used to crack at the converter bolt holes. From the converter bolt holes to the outside. There is more meat from the converter bolt holes to the outside of the flexplate on the mopar SFI flexplate.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Can i reuse my flex plate [Re: Dartsport540] #2230003
01/08/17 01:36 PM
01/08/17 01:36 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Thanks guys, I ordered the PRW flex plate from hughes. They said they have been selling it for yrs without issues.
