Ultradyne closed some years ago,Bullet and Lunati cams can grind these lobes.I use Bullet but I am less than 15 mnutes from Comp/Lunati and Bullet cams. The cam card the op posted is at least 20 years old but the grind should work fine in the right mild application.
I called the phone number I have for Ultrdyne first and got a answer from one of the guys that worked at Ultrdyne when Harold sold it to the guys at Bullett, he explained to me that they, both companies, are still in Mississippi (SP
) and they are about six miles from Comps and Lunati buildings in Memphis, TN
I thought they where down close to the gulf, not anywhere near Memphis,TN
I also found out that Holley had sold Lunati to Comp several years back, I did not know that
My how times have changed
