Re: Cold weather 400 block.
[Re: mopar dave]
#2224128
12/31/16 05:03 PM
12/31/16 05:03 PM
Thumperdart
State of confusion
Didnt you say awhile back that your block had 2 cyl that were .120 or less on thrust? Ya, had one .118 in the non thrust area but most are .200+.........Just took it out for some carb tuning and I just can't kill this thing.......... ![punkrocka punkrocka](/ubbthreads/images/graemlins/custom/punkrocka.gif)
[Re: mopar dave]
#2224187
12/31/16 06:28 PM
12/31/16 06:28 PM
Thumperdart
State of confusion
Maybe better, after all I just run the lowly RPM's w/a slightly bigger than standard port opening...........
[Re: ccdave]
#2224297
12/31/16 09:14 PM
12/31/16 09:14 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
And the benifit of a cold weather block is????
What happens if the infamous 230 block has core shift ?
A good block is a block that has thick consistent cylinder wall thickness. I really could care less what year or what the casting number is. Sadly, I have not heard of any true cold weather block having thick bores. There has always been a few cylinders that were thin. I have one myself but have not yet sonic checked it. But only heard of about 4 being Sonic checked because they are rare. Hope mines a exception. Do love the thick crank journals though. A standard 400 journal is about twice the size of a 440,s The 230 infamous blocks journal is about twice the size of a 400,s journals. Don't know why that is if they didn't bother to make the bores thicker. Mines probably thin too.
[Re: EchoSixMike]
#2224439
01/01/17 01:04 AM
01/01/17 01:04 AM
Posts: 201 PA
Scully
PA
Meh, sleeve it. We do it all the time. I'll give you $25 for that rejected block. S/F....Ken M How would sleeving it make the cylinders any thicker.
[Re: Scully]
#2224612
01/01/17 11:56 AM
01/01/17 11:56 AM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Meh, sleeve it. We do it all the time. I'll give you $25 for that rejected block. S/F....Ken M How would sleeving it make the cylinders any thicker. It might not, but it will fix a problem and add strength at the same time. Much better material, consistent thickness. Guys have gone as far as to sleave all eight holes looking for better ring seal and strength.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: Scully]
#2224653
01/01/17 01:09 PM
01/01/17 01:09 PM
Posts: 494 IL
EchoSixMike
IL
Meh, sleeve it. We do it all the time. I'll give you $25 for that rejected block. S/F....Ken M How would sleeving it make the cylinders any thicker. It may not make it thicker, but that doesn't matter, it absolutely makes it stronger. Even .150(let's say) of virgin 2016 production 100k psi ductile iron is far stronger than .250+ of 1978 crusty grey iron from a Monday shift in Detroit. We probably sleeve at least a block a month that big power (1000+hp) nitrous and turbo guys smash with "overly optimistic" tunes. S/F....Ken M
[Re: EchoSixMike]
#2224896
01/01/17 04:56 PM
01/01/17 04:56 PM
Posts: 4,457 Washington
madscientist
Washington
Meh, sleeve it. We do it all the time. I'll give you $25 for that rejected block. S/F....Ken M How would sleeving it make the cylinders any thicker. It may not make it thicker, but that doesn't matter, it absolutely makes it stronger. Even .150(let's say) of virgin 2016 production 100k psi ductile iron is far stronger than .250+ of 1978 crusty grey iron from a Monday shift in Detroit. We probably sleeve at least a block a month that big power (1000+hp) nitrous and turbo guys smash with "overly optimistic" tunes. S/F....Ken M Crusty grey iron from a Monday shift in Detroit!!!!!!!!!!!!! There is s hit song in there somewhere.
