Re: Ceramic coated vs steel headers [Re: dickdale] #2229224
01/07/17 11:06 AM
01/07/17 11:06 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Originally Posted By dickdale
What are the pro and cons on Ceramic coated headers?
Which one can I buy besides the expensive TTI headers for my 70's Satellite with manual steering and a 440cui? It has ported heads and a mild cam.
I was think about 1 3/4 tubes and a 3 inch collector.
Any thought?
Your location makes it tough for you , I assume you can get those type of coatings done in Europe ? If so I would buy them bare , test fit to the car and ding where needed , they WILL need it , then have them coated.
Mainstream Media is the new Pravda
Re: Ceramic coated vs steel headers [Re: JohnRR] #2229776
01/07/17 10:01 PM
01/07/17 10:01 PM
IN
ahy Offline
ahy  Offline
IN
The ceramic coating inside and out really helps keep heat out of the engine compartment. Plus it holds up well and looks better vs steel or paint. My 15+ year old coated TTI's are doing fine and no heat problems even with long X country drives in hot weather.
