Re: Ceramic coated vs steel headers
[Re: dickdale]
#2225663
01/02/17 04:35 PM
01/02/17 04:35 PM
Posts: 15,888 Omaha Ne
TJP
Omaha Ne
I have been very disappointed with the ceramic coatings we have received from multiple manufacturers as well as the local powder coaters. Even if they look good initially within a couple of years rust starts appearing between the tubes etc. They also sometimes discolor near the ports if idled for more than 5 or so minutes. We received a set from hooker last week that were so bad I sent them back and did the VHT thing. If a customer wants the ceramic coating we order the non coated headers in, test fit them and then send them to Jet Hot. PITA but the quality speaks for itself. Otherwise strip and coat with VHT. A pet peeve of mine is why they don't offer the non coated headers with a hi temp paint. The cr-p they use burns off immediately. Stripping it off to repaint is a time consuming PITA!!! I would gladly pay 50.00 more for black headers that didn't have to be stripped and redone
[Re: GoodysGotaCuda]
#2225664
01/02/17 04:35 PM
01/02/17 04:35 PM
Posts: 16,015 RI Deep in the rust belt
chargervert
I got a pair of TTI polished ceramic headers for my 472 Hemi,and they are like jewels!
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: dickdale]
#2225674
01/02/17 04:44 PM
01/02/17 04:44 PM
Posts: 21,562 A collage of whims
topside
A collage of whims
The coatings also seem to stay nice forever, unlike most paints. Most header manufacturers offer the coating option, though some may be better coatings than others. I always cut the head flanges - to avoid warping, allow better plug access, and better appearance - which complicates that and means I need to have them coated after working on them. Some of the guys here with Hookers, Hedmans, etc will likely post their experiences & recommendations. The smaller tubes generally are easier to install, of course, and for a street car 440, 1 3/4" primaries should be fine. Some other considerations are spark plug & wire clearance, how close to the valve covers (gasket life), & starter clearance. I once bought some Hedmans for a 440/early B swap that placed the collector high enough that I had to use S-bends to clear the torsion-bar crossmember and use a mini-starter. That was a false economy, like Goody said.
[Re: dickdale]
#2225803
01/02/17 07:37 PM
01/02/17 07:37 PM
Posts: 4,831 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I can tell you a non coated thick quality steel holds up better than the thin low quality steel. For example- the "Black Jack" header type el cheapo steel we all know of looks like brake lines on a 15 year old MI car after like 18 months. But the thick steel headers doesnt swell up with rust and crust but rather a sound uniform surface rust. Paint coatings last and perform better on the higher quality steel. My brothers Duster has 11 year old Schumacher shorties- raw steel. Yes their is rust but surface only-metal is still strong with no compromises.
Keep old mopars alive.
[Re: dickdale]
#2225875
01/02/17 09:25 PM
01/02/17 09:25 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
The ceramic coating looks nice but it's brittle like paint, don't expect it to hold up like powder coat or chrome. It will scratch off easily.
**Photobucket sucks**
[Re: dickdale]
#2225913
01/02/17 10:21 PM
01/02/17 10:21 PM
Challenger 1
Cincinnati, Ohio
Get the heat barrier inside the header tubes, then the outside coating holds up much better. Plus it makes for a quieter, cooler running header. My TTI 340 headers are 20 years old last year and are holding up well. I drive the hell out of that car in extreme conditions. On my 3rd motor, same headers.
Is the ceramic coating on the outside perfect after 20 years?, hell no! But the coated headers is one of the best investments I have ever made on my car. They would not have lasted 20 years without the coating.
Edit...my headers are 30 years old now. Installed in 1986.
[Re: Neil]
#2226134
01/03/17 03:00 AM
01/03/17 03:00 AM
Posts: 632 Zombieland
Car Nut
Zombieland
I wish they would just skip the coatings and make them in stainless instead. Cost would be more, but worth it I would think.
I bought raw steel TTI headers as back during that time frame people on here were having issues with the coating getting toasted during engine break-ins - timing/jetting out of whack and no airflow. Figured it would be easier to just break them in raw on the engine test stand and coat them before going into the car. I also wanted some color other than the silver that everyone else has as well. TTI will custom bend headers out of stainless steel.
[Re: Car Nut]
#2226265
01/03/17 01:11 PM
01/03/17 01:11 PM
Posts: 23,321 Here
jcc
Here
I bought raw steel TTI headers as back during that time frame people on here were having issues with the coating getting toasted during engine break-ins - timing/jetting out of whack and no airflow. Figured it would be easier to just break them in raw on the engine test stand and coat them before going into the car. I also wanted some color other than the silver that everyone else has as well. TTI will custom bend headers out of stainless steel. That's great, I did not know that, is the cost increase within reason? I had a set SS headers on my Tacoma coated, the coating lasted over 200K miles.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: dickdale]
#2227672
01/05/17 11:33 AM
01/05/17 11:33 AM
Posts: 13,501 Marion, South Carolina [><]
an8sec70cuda
I have had good luck w/ the TTI headers and their ceramic coating. After having a set that's coated, you'll never want anything else...except stainless if you have the money.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: dickdale]
#2229072
01/07/17 12:59 AM
01/07/17 12:59 AM
Posts: 314 Medina, OH
dart440_72
Medina, OH
I bought a bare set of TTI headers for my car. There was a little surface rust on them. I welded the O2 bungs in and shipped them off to Swain Tech for their white lighting coating. Super durable coating. Painted it with high heat paint and perfect so far
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
