Re: 38 hits the road pics.
[Re: beesting]
#222554
02/19/09 02:40 AM
02/19/09 02:40 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
Thanks, beesting. Any chance you've got some more detailed pic of the frontend install? One is coming without a frame, and one with. I located a Dak for reasonable $$$ but was wondering which frontend I'd prefer in the stock frame. I was thinking MII, but I have a couple transverse T-bar units, so I could make use of what I already have onhand...
2 Demons...no, not my kids!
Re: 38 hits the road *update* more pics.
[Re: beesting]
#222557
02/22/09 01:45 AM
02/22/09 01:45 AM
Posts: 417 lisbon,ohio
beesting
Still a member
Still a member
lisbon,ohio
pic 2
[Re: beesting]
#222559
02/22/09 02:50 AM
02/22/09 02:50 AM
4speeds4me
Thanks for the pic!
No MII for me! Bucks down. TIGHT budget...especially with work the way it is right now.
If you get the chance, can you get a pic of how you've mounted the rear of the crossmember? The front part is good and clear, but the rear point looks like it's hidden behind the knuckle and brakes and all. If you can't get a pic, even a decent written description would be a good start to help me out.
Thanks Again!
[Re: 4speeds4me]
#222560
02/22/09 08:45 PM
02/22/09 08:45 PM
Posts: 2,048 N.E.Ohio
Polarabill
N.E.Ohio
I had to work ovetime fri and sat and couldn't believe how much got done in those couple of days.When I left today it was off the jackstands.The exhaust is on.Carpet is on the floor,shifter and boot completed.Door and back glass are in. More stuff gets done every day This thing should be roadworthy within a couple more weeks barring a disaster.AND, we are still having fun doing it.
This would be so much easier if I knew what I was doing...
[Re: beesting]
#222562
02/26/09 12:14 AM
02/26/09 12:14 AM
beesting
Still a member
Still a member
lisbon,ohio
next
[Re: 4speeds4me]
#222565
02/26/09 07:51 AM
02/26/09 07:51 AM
Posts: 59 Ontario, Canada
dodge41
Ontario, Canada
Wow, when you guys are done that truck, I have a 41 that needs a bunch of guys to come help me finish (or start, depending on if you're a glass half full or empty kind of guy)! But bring your snow shovels and winter coats, because the truck is buried and my garage isn't heated! But a plus is that our beer is good here ! Nice work Matt
[Re: beesting]
#222569
02/26/09 05:30 PM
02/26/09 05:30 PM
Posts: 2,833 Ontario Canada
Webster
Ontario Canada
last 1 inside cab
Next question...What kind of seats and do you much room in the cab?? Great looking Truck looks like fun
