Page 2 of 3 1 2 3
Re: 38 hits the road pics. [Re: beesting] #222554
02/19/09 02:40 AM
02/19/09 02:40 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Thanks, beesting. Any chance you've got some more detailed pic of the frontend install? One is coming without a frame, and one with. I located a Dak for reasonable $$$ but was wondering which frontend I'd prefer in the stock frame. I was thinking MII, but I have a couple transverse T-bar units, so I could make use of what I already have onhand...
2 Demons...no, not my kids!
Re: 38 hits the road pics. [Re: 4speeds4me] #222555
02/22/09 01:36 AM
02/22/09 01:36 AM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
4speeds4me this is the only pic i have hope it helps heard a mustang II would be easier if you have the money
Re: 38 hits the road pics. [Re: beesting] #222556
02/22/09 01:42 AM
02/22/09 01:42 AM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
more updates primer, glass, front fenders and the grill pic 1
Re: 38 hits the road *update* more pics. [Re: beesting] #222557
02/22/09 01:45 AM
02/22/09 01:45 AM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
pic 2
Re: 38 hits the road *update* more pics. [Re: beesting] #222558
02/22/09 01:48 AM
02/22/09 01:48 AM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
pic 3 hard to belive its only been a little over a week
Re: 38 hits the road pics. [Re: beesting] #222559
02/22/09 02:50 AM
02/22/09 02:50 AM
4speeds4me Offline
4speeds4me  Offline
Thanks for the pic!
No MII for me! Bucks down. TIGHT budget...especially with work the way it is right now.
If you get the chance, can you get a pic of how you've mounted the rear of the crossmember? The front part is good and clear, but the rear point looks like it's hidden behind the knuckle and brakes and all. If you can't get a pic, even a decent written description would be a good start to help me out.
Thanks Again!
Re: 38 hits the road pics. [Re: 4speeds4me] #222560
02/22/09 08:45 PM
02/22/09 08:45 PM
N.E.Ohio
P
Polarabill Offline
Polarabill  Offline
P
N.E.Ohio
I had to work ovetime fri and sat and couldn't believe how much got done in those couple of days.When I left today it was off the jackstands.The exhaust is on.Carpet is on the floor,shifter and boot completed.Door and back glass are in. More stuff gets done every day This thing should be roadworthy within a couple more weeks barring a disaster.AND, we are still having fun doing it.
This would be so much easier if I knew what I was doing...
Re: 38 hits the road pics. [Re: Polarabill] #222561
02/26/09 12:09 AM
02/26/09 12:09 AM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
had touble down loading pics from last few days but heres todays backed it out and turned it around under its own power!!!!
Re: 38 hits the road pics. [Re: beesting] #222562
02/26/09 12:14 AM
02/26/09 12:14 AM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
next
Re: 38 hits the road pics. [Re: beesting] #222563
02/26/09 12:16 AM
02/26/09 12:16 AM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
last 1 inside cab
Re: 38 hits the road pics. [Re: beesting] #222564
02/26/09 01:25 AM
02/26/09 01:25 AM
4speeds4me Offline
4speeds4me  Offline
VERY cool!
Re: 38 hits the road pics. [Re: 4speeds4me] #222565
02/26/09 07:51 AM
02/26/09 07:51 AM
Ontario, Canada
dodge41 Offline
dodge41  Offline
Ontario, Canada
Wow, when you guys are done that truck, I have a 41 that needs a bunch of guys to come help me finish (or start, depending on if you're a glass half full or empty kind of guy)! But bring your snow shovels and winter coats, because the truck is buried and my garage isn't heated! But a plus is that our beer is good here !
Nice work
Matt
Re: 38 hits the road pics. [Re: beesting] #222566
02/26/09 02:24 PM
02/26/09 02:24 PM
Cambridge Idaho
RUMBLON Offline
RUMBLON  Offline
Cambridge Idaho
last 1 inside cab
Is that vinyl flooring for door panels?
Re: 38 hits the road pics. [Re: RUMBLON] #222567
02/26/09 04:23 PM
02/26/09 04:23 PM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
lawfish the metal bed floor was bad and the pc of wood in the bed didnt look good and i didn't have money to replace either one so we went with a pc of linoleum so polarabill had a pc of that card board stuff to make door skins so we used left over linoleum and covered them
Re: 38 hits the road pics. [Re: beesting] #222568
02/26/09 04:39 PM
02/26/09 04:39 PM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
dodge 41 I had to have mine towed to my freinds garage to have heat and freinds help, know any tow truck drivers that would bring it down just put the beer in the bed I still can't believe everything thats been done in two weeks
Re: 38 hits the road pics. [Re: beesting] #222569
02/26/09 05:30 PM
02/26/09 05:30 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
last 1 inside cab
Next question...What kind of seats and do you much room in the cab?? Great looking Truck looks like fun
Re: 38 hits the road pics. [Re: Webster] #222570
03/01/09 08:01 PM
03/01/09 08:01 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Love it
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 38 hits the road pics. [Re: BloFish] #222571
03/02/09 10:43 PM
03/02/09 10:43 PM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
well good enough to drive it home this past saturday about 10 miles tracked great and ran good still need somthings running boards and rollpan made and some warm weather. here's to good freinds and big brother. thank you!
Re: 38 hits the road pics. [Re: Webster] #222572
03/03/09 08:13 PM
03/03/09 08:13 PM
N.E.Ohio
P
Polarabill Offline
Polarabill  Offline
P
N.E.Ohio
Beesting may have missed this question so I will answer as best I can for him.The seats are out of a Chrysler of some sort,but not sure what.Room for the driver is very limited and he is going to look into different seats.I think a low back bucket would work real well and Beesting thinks the back seat from a caravan would fit nicely.
Re: 38 hits the road pics. [Re: beesting] #222573
03/03/09 08:17 PM
03/03/09 08:17 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
TRUCKS looking good
it had to be a fun ride home,
it sure has come a long way in a short time Ron...
Page 2 of 3 1 2 3
