Page 2 of 3 1 2 3
Re: Cold weather 400 block. [Re: ccdave] #2224106
12/31/16 03:34 PM
12/31/16 03:34 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Yep, major side. Same as doms. I am aware of this. Thats why it got filled.
Re: Cold weather 400 block. [Re: mopar dave] #2224110
12/31/16 03:39 PM
12/31/16 03:39 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Hopefully the fill will help. Thrust sides are typically an additional .100 thick.
Re: Cold weather 400 block. [Re: mopar dave] #2224127
12/31/16 04:01 PM
12/31/16 04:01 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
like some say,dont matter if cold weather block or not,wall thickness is where its at,i fill all my blocks anyway,there coming out with low deck cross bolted blocks away which might be a way to go
Re: Cold weather 400 block. [Re: mopar dave] #2224128
12/31/16 04:03 PM
12/31/16 04:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By mopar dave
Didnt you say awhile back that your block had 2 cyl that were .120 or less on thrust?
Ya, had one .118 in the non thrust area but most are .200+.........Just took it out for some carb tuning and I just can't kill this thing.......... punkrocka
Re: Cold weather 400 block. [Re: Thumperdart] #2224142
12/31/16 04:28 PM
12/31/16 04:28 PM
Mt Morris Michigan
Mt Morris Michigan
I hope it lives a long life Dom.
Re: Cold weather 400 block. [Re: ccdave] #2224144
12/31/16 04:34 PM
12/31/16 04:34 PM
Mt Morris Michigan
Mt Morris Michigan
I started a thread on this topic about a year or two ago. I posted the sonic numbers in it. Ill see if i can find.
Re: Cold weather 400 block. [Re: mopar dave] #2224165
12/31/16 04:57 PM
12/31/16 04:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Everything breaks eventually so I keep it outta detonation and keep it at 7000 r's usually.......... thumbs
Re: Cold weather 400 block. [Re: Thumperdart] #2224178
12/31/16 05:13 PM
12/31/16 05:13 PM
Mt Morris Michigan
Mt Morris Michigan
I hope mine runs that good.
Re: Cold weather 400 block. [Re: mopar dave] #2224187
12/31/16 05:28 PM
12/31/16 05:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Maybe better, after all I just run the lowly RPM's w/a slightly bigger than standard port opening...........
Re: Cold weather 400 block. [Re: ccdave] #2224297
12/31/16 08:14 PM
12/31/16 08:14 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By ccdave
And the benifit of a cold weather block is????
What happens if the infamous 230 block has core shift ?
A good block is a block that has thick consistent cylinder wall thickness. I really could care less what year or what the casting number is.
Sadly, I have not heard of any true cold weather block having thick bores. There has always been a few cylinders that were thin. I have one myself but have not yet sonic checked it. But only heard of about 4 being Sonic checked because they are rare.
Hope mines a exception. Do love the thick crank journals though. A standard 400 journal is about twice the size of a 440,s The 230 infamous blocks journal is about twice the size of a 400,s journals. Don't know why that is if they didn't bother to make the bores thicker. Mines probably thin too.
Re: Cold weather 400 block. [Re: mopar dave] #2224346
12/31/16 09:28 PM
12/31/16 09:28 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I wouldn't use a block with .120 on a major thrust side. NO WAY!!! Unless it was a stock ci low compression build. Especially if I'm building a motor for someone else . Hopfully that measurement is after the bore and hone.....That's just me however. Your block may end up being just fine for several years....... Good Luck and Happy New Year....
Re: Cold weather 400 block. [Re: ccdave] #2224348
12/31/16 09:32 PM
12/31/16 09:32 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks. Happy New Year.
Re: Cold weather 400 block. [Re: mopar dave] #2224377
12/31/16 10:37 PM
12/31/16 10:37 PM
Texas
mprhound Offline
mprhound  Offline
Texas
Here is the sonic check on my 230 thick main block, all of these are the thinnest places on the bore checked top middle and bottom
Re: Cold weather 400 block. [Re: EchoSixMike] #2224439
01/01/17 12:04 AM
01/01/17 12:04 AM
PA
Scully Offline
Scully  Offline
PA
Originally Posted By EchoSixMike
Meh, sleeve it. We do it all the time. I'll give you $25 for that rejected block. S/F....Ken M
How would sleeving it make the cylinders any thicker.
Re: Cold weather 400 block. [Re: mprhound] #2224545
01/01/17 02:15 AM
01/01/17 02:15 AM
Mt Morris Michigan
Mt Morris Michigan
#1 on major thrust was thinnest on mine. #8 was next with .158 minor thrust. Rest are all near .300.
Re: Cold weather 400 block. [Re: Scully] #2224612
01/01/17 10:56 AM
01/01/17 10:56 AM
gregsdart Offline
gregsdart  Offline
It might not, but it will fix a problem and add strength at the same time.
Much better material, consistent thickness. Guys have gone as far as to sleave all eight holes looking for better ring seal and strength.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Cold weather 400 block. [Re: Scully] #2224653
01/01/17 12:09 PM
01/01/17 12:09 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
It may not make it thicker, but that doesn't matter, it absolutely makes it stronger. Even .150(let's say) of virgin 2016 production 100k psi ductile iron is far stronger than .250+ of 1978 crusty grey iron from a Monday shift in Detroit.
We probably sleeve at least a block a month that big power (1000+hp) nitrous and turbo guys smash with "overly optimistic" tunes. S/F....Ken M
Re: Cold weather 400 block. [Re: EchoSixMike] #2224896
01/01/17 03:56 PM
01/01/17 03:56 PM
Washington
madscientist Offline
Washington
Crusty grey iron from a Monday shift in Detroit!!!!!!!!!!!!!
There is s hit song in there somewhere.
Re: Cold weather 400 block. [Re: madscientist] #2224982
01/01/17 05:40 PM
01/01/17 05:40 PM
dogdays Offline
dogdays  Offline
The nodular or ductile iron sleeve has a higher tensile strength so it handles the pressure better.
The nodular or ductile iron sleeve is 50% stiffer, modulus of elasticity 30million vs 20million for grey iron.
A while back I read a quote from a big engine shop that said most 400 blocks they received had one or two cylinders that needed to be sleeved. If you put another $300 into the block sleeving two and it's a cold weather block then you have decent cylinders AND thicker webs.
One other thing; All cold weather blocks are 230 blocks but not all 230 blocks are cold weather blocks.
R.
Re: Cold weather 400 block. [Re: dogdays] #2225049
01/01/17 07:30 PM
01/01/17 07:30 PM
Mt Morris Michigan
Mt Morris Michigan
Thats the conclusion. Thanks guys. Cold weather block or not, my block has huge main webs and is filled above soft plugs. Im running it.
Page 2 of 3 1 2 3
