Page 2 of 5 1 2 3 4 5
Re: Article on Muscle Motors new block [Re: AndyF] #2219492
12/23/16 11:28 AM
12/23/16 11:28 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Hopefully, everything works out and this becomes a deal that MOPAR guys are in dire need of, but I have one question....
With a 4.800 bore center, how can a block at 4.500 have over .400 at it's narrowest point - the area adjacent to the hemi-specific exhaust pushrod clearance scallop......as stated in one of the picture captions??? Wouldn't the narrowest point be between the cylinders at 4.500???
Re: Article on Muscle Motors new block [Re: AndyF] #2219496
12/23/16 11:42 AM
12/23/16 11:42 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I'm just happy that they're making low deck blocks too. boogie
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Article on Muscle Motors new block [Re: jim sciortino] #2219498
12/23/16 11:44 AM
12/23/16 11:44 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Yeah, that's exactly what I was curious about.
Re: Article on Muscle Motors new block [Re: MR_P_BODY] #2219557
12/23/16 01:15 PM
12/23/16 01:15 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Originally Posted By MR_P_BODY
I wonder why they didnt go ahead and drill the
cross bolts on #5 specially since its prepped
for it.. but at least there is a STRONG block
for the BB guys... my mega block with 4.5 bores
only had .200 walls at the thinnest point.. whats
the next ring size over a 4.5.. does chevy have a
4.6 ring
wave
4.6 is a common BBC size. The biggest bore I have seen for a 4.84 bore space was 4.605. I believe that the Dart block can go 4.625 at 4.84 bore space.
Re: Article on Muscle Motors new block [Re: B1MAXX] #2219565
12/23/16 01:26 PM
12/23/16 01:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I thought it was.. but wasnt sure.. thanks
wave
Re: Article on Muscle Motors new block [Re: MR_P_BODY] #2219576
12/23/16 01:33 PM
12/23/16 01:33 PM
Apollo, PA.
Apollo, PA.
I thought I remember seeing a mopar block at 4.600 listed as max bore in the older mopar performance catalog (maybe 1990's-2000's)
Re: Article on Muscle Motors new block [Re: AndyF] #2219597
12/23/16 01:52 PM
12/23/16 01:52 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I wish Mike at MM the best of luck with this venture.
Lord knows the BB guys sure could benefit from having these things available.
If the quality is consistantly decent, and they prove they can be delivered in a timely fashion, I expect they'll sell tons of them.
Re: Article on Muscle Motors new block [Re: AndyF] #2219623
12/23/16 02:20 PM
12/23/16 02:20 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I think .400" is on the thrust surfaces, not between adjacent bores.
Boffin Emeritus
Re: Article on Muscle Motors new block [Re: polyspheric] #2219700
12/23/16 04:38 PM
12/23/16 04:38 PM
Trumbull,CT.
Trumbull,CT.
That makes sense.
I would think a 4.600 bore is not out of the question, especially in a big effort N/A build, since .200 between cylinders is typically enough to seal properly in a non-power adder application.
Re: Article on Muscle Motors new block [Re: AndyF] #2219754
12/23/16 06:35 PM
12/23/16 06:35 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
They called me today to give me an update. I've got one of the first 10 that they cast. Its coming along..............
Re: Article on Muscle Motors new block [Re: markz528] #2219761
12/23/16 06:54 PM
12/23/16 06:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
So when is your date for pick up/ or ETA and
when did you put you order in.. thanks...
and what did you order
wave
Re: Article on Muscle Motors new block [Re: AndyF] #2219781
12/23/16 07:14 PM
12/23/16 07:14 PM
So. Burlington, Vt.
So. Burlington, Vt.
Hopefully they can be able to continually have them going through the process.
I'm sure the BB Mopar crowd will be timid about laying down big deposits initially, which means the cash flow for MM may be a bit tough in the early going of this endeavor...... But I think in the end it will be a case of "if you build it, they will come".
Re: Article on Muscle Motors new block [Re: MR_P_BODY] #2219787
12/23/16 07:27 PM
12/23/16 07:27 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
wave
I ordered it in July with the understanding that I would get it in the spring. Honestly I probably won't need it till at least summer.
I ordered it as a rotating short block. It is a RB and will be a 512 cubic inch with Molnar crank and rods. This is a street/strip build with target of 650 hp. Its getting a set of Todd Marsh side winder heads. Pretty tame build.
The first motor of the 10 is machined and assembled. Getting ready to hit the dyno - they want to verify all is good before machining the rest of them.
At this time getting the motor in the spring is probably realistic based on current info.
Re: Article on Muscle Motors new block [Re: AndyF] #2220050
12/24/16 11:27 AM
12/24/16 11:27 AM
Malvern Pa
500ci barracuda Offline
Malvern Pa
Nice block. I am looking for a new block to build a 600ci. Anyone know the cost of this block. Mark
Re: Article on Muscle Motors new block [Re: AndyF] #2220108
12/24/16 01:29 PM
12/24/16 01:29 PM
Trumbull,CT.
Trumbull,CT.
$3800 with about $1300 in options.......not counting final hone.
Re: Article on Muscle Motors new block [Re: 500ci barracuda] #2220140
12/24/16 02:13 PM
12/24/16 02:13 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The linked article contains a list of options available and their associated costs above & beyond the $3800 base price.
Re: Article on Muscle Motors new block [Re: AndyF] #2220149
12/24/16 02:23 PM
12/24/16 02:23 PM
CA
bbodee Offline
bbodee  Offline
CA
Oh man, I want one. Time to start saving for one. I hope this turns out to be a solid product. I wish MM the best on this project.
Re: Article on Muscle Motors new block [Re: AndyF] #2220267
12/24/16 04:52 PM
12/24/16 04:52 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
I know some serious bracket guys that want cast iron blocks due to being more consistent by holding heat but other than that if a cast iron block is $5000 why wouldn't you spend another $1000 and get an aluminum block. Not being critical at all just curious what people's opinions are.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Article on Muscle Motors new block [Re: MR_P_BODY] #2220299
12/24/16 05:46 PM
12/24/16 05:46 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
4.6 ring
wave
4.600 and 4.625 are common sizes for BBC 565 cu in strokers in 9.8 deck Dart Big M blocks....lots of rings available....I'm learning it all for S/C and S/P racing....it's like learnig to speak all over again.
Re: Article on Muscle Motors new block [Re: Chassisman] #2220337
12/24/16 06:44 PM
12/24/16 06:44 PM
Superfreak
Superfreak
4.6 ring
wave
Also in the 10.2 deck heights.
