Page 38 of 85 1 2 36 37 38 39 40 84 85
Re: paint job on a budget!? [Re: Exit1965] #22230
03/19/06 10:26 PM
03/19/06 10:26 PM
Great Lakes State
O
ONEBADBIRD Offline
ONEBADBIRD  Offline
O
Great Lakes State
Exit1965. Hats off to you man Looks great!! Professional Rustoleum it is then I agree!!! O.K. everybody get out your rollers and start painting them cars now. I will also start my ride in about 2 months I can't wait. Thanks for yours (exit1965) and 69chargers "101 class" on this great money saving idea It just might make it possible to get the ride on the road by this fall. All I need now is the time. Thanks Jay
Fair winds, and following seas! Red sky at night sailor's delight, red sky in morning sailor take warning! Weather from the West is always best! Weather from the East is not fit for man nor beast!
Re: paint job on a budget!? #22231
03/19/06 10:47 PM
03/19/06 10:47 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Here's the professional can and the standard can. Just to be safe I think I'll go to lowes and buy 4-5 quarts just so I have it.
I know 69charger said he used under a gallon for his charger. i'm going to plan on screwing up a few times, so I would buy at least a gallons worth + a quart for an old mopar.
jagd, you might want to wait a while to see if it hardens up for you, then if not consider putting 2 more coats like you said, after wetsanding with 800 or so.
Re: paint job on a budget!? [Re: Jerry] #22232
03/19/06 10:52 PM
03/19/06 10:52 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
ok heres a question. i only found rustoleum professional in the quart cans. how many cans will it take to paint a whole car? i plan on doing black. now if i need to buy quart cans should i mix all of them together first to make sure the pigment is even? i know on jambs and trunks and engine compartment it won't matter but for the surface it might. if i did one panel at a time. whats the opinion on this? also is there a base rustomleum professional that can be tinted or do you have to use the colors available? if it can be tinted i might go with something other than black.
I plan on mixing 4 quarts together in a gallon can just to make sure the color is the same. For the last test run, I've opened the rustoleum can ONCE - and poured it into a yogurt container with a nice lid, and mixed the mineral spirits in with it. I kept using that mixture over the past 5 days, just adding a bit of mineral spirits each time as it seems to thicken up a bit over a day.
if you haven't practiced (even if you have...), plan on screwing up a few times so get enough paint where you dont have to worry..
Re: paint job on a budget!? [Re: Exit1965] #22233
03/20/06 12:11 AM
03/20/06 12:11 AM
Anonymous OP
Anonymous OP
I'll see how it feels after a month or so and then maybe go back over it.
I am painting my car 2 different colors (red and white), I noticed that the red mixes VERY differently than the white with mineral spirits. It takes a lot more mineral spirits to thin it, and it tends to bubble more than the white for some reason.
Re: paint job on a budget!? #22234
03/20/06 10:00 AM
03/20/06 10:00 AM
Anonymous OP
Anonymous OP
Looks awesome, Exit! That came out very nice, even with the garage light. I was concerned with the Professional, because I thought that shine might not have been as high of a priority as durability. I'm going to pick some of that up and do the reverse side of my test panel.
In retrospect with my unsuccessful test, my prep sucked (didn't get all of the oil off the surface from the mill), and I laid the coats way too thick. However, I can go back to my panel now (it's been about a month) and I can't put my fingernail through to the bare metal. I used red, and as Jag indicated, I think it requires a bit more mineral spirits than some of the other colors.
I'll probably start rolling my dune buggy next month. Thanks for all of the insight and updates, guys...
Re: paint job on a budget!? #22235
03/20/06 10:22 AM
03/20/06 10:22 AM
toronto canada
69chargeryeehaa Offline
toronto canada
nice exit1965, glad to hear the professional worked out for you. i really think that it is a CA thing, other people have no issues with the standard rustoleum. as for mixing the quarts together, it could'nt hurt, but i have to say at least with the tremclad i bought a can 3 years later to repaint a fender due to parking lot damage, and the color was an exact match. also i know that some stores carry only quart cans, like the tremclad i had to go to 3 stores before i found it in a gal can. exit-start rollering that damm car, i saw in the pic how badly it wants a nice coat of paint and get out of that damm garage!!!
Re: paint job on a budget!? #22236
03/20/06 10:53 AM
03/20/06 10:53 AM
Anonymous OP
Anonymous OP
I will agree with the first part of your observations. With the consumer grade paint, I found the Gloss White to be significantly thicker than the Gloss Sunrise Red right out of the can. However, when I got the dilution right, I saw no difference in how it applied.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #22237
03/20/06 11:18 AM
03/20/06 11:18 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Man, the paint job is going to be the easy (and cheap!) part. It has no drivetrain, but I have a '66 383/727 out of a Fury I'll be dumping in it.. hope to have it out of the garage under its own power this summer!
Re: paint job on a budget!? [Re: Exit1965] #22238
03/20/06 12:07 PM
03/20/06 12:07 PM
Anonymous OP
Anonymous OP
Now that I know this paint job works, I need to get Home Depot to blend me some sublime green to paint my Challenger with!
What I really need is someone local who can do body work for me, I need some metal welded in, and that's something I can't do
Re: paint job on a budget!? [Re: Exit1965] #22239
03/20/06 01:01 PM
03/20/06 01:01 PM
Anonymous OP
Anonymous OP
great post! I have someone picking up some tremclad very soon for me. I wanna do a test of that and the proffesional rustolem to see side by side differences.
Is there a page online that shows all the available tremclad colors? All I see when I go to the website is a pic of the spay can.
Re: paint job on a budget!? #22240
03/20/06 01:41 PM
03/20/06 01:41 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I used Rustoleum spraybomb professional on the gas tank of the sig car. I did it about 10 years ago, and it's still holding up well. I live on a dirt road too, so you know rocks get thrown at it regularly. It gets harder than the regular rustoleum and is a whole lot less gummy/sticky.
Rich H.
Esse Quam Videri
Re: paint job on a budget!? [Re: ZIPPY] #22241
03/21/06 12:03 PM
03/21/06 12:03 PM
Anonymous OP
Anonymous OP
hey guys, i dont wanna sound redundant but i too have been following this thread ever since it started and man o man am i excited to get started on my car. I just bought a cheap project car which definetly needs cosmetic help. Here's a pic. And i need some help. These people used this car as a parade car through art festivals and what not.The art work on the car seems to be with acrylic paint and is very thick. I'm trying to sand it down but is taking forever. I will be painting it with RUST-OLEUM that i got tinted from homedepot last night to a METROPOLITAN tint. What is the best method of sanding down this car to a somewhat smooth surface for rust-oleum to be smooth or will the end result be thick enough to smoothen out itself? Thanks for all the good info GUYs!!!
Re: paint job on a budget!? #22242
03/21/06 12:23 PM
03/21/06 12:23 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Dont expect the rustoleum to be thick enough to cover any surface issues up! especially high spots from old artwork. Spend time sanding to get the surface very smooth, or it will definately show.
what grit are you using and what type of block? I would think 100 or 120 would be a good start for the artwork without doing too much extra damage to the surrounding paint, then go over it with 180 or 220 to get rid of sanding scratches before painting.
Re: paint job on a budget!? [Re: Exit1965] #22243
03/21/06 12:45 PM
03/21/06 12:45 PM
toronto canada
toronto canada
you could also try a palm sander with 80 grit and light pressure.
Re: paint job on a budget!? #22244
03/21/06 01:00 PM
03/21/06 01:00 PM
Anonymous OP
Anonymous OP
Personally - just frame the art and buy something else and start over!! Or.......remember the saying "If you can't fix it, feature it" and build your project around the art.
Curious, what kind of project are you doing - at first I thought it was a Fiesta, but is it a Civic?
Re: paint job on a budget!? #22245
03/21/06 03:42 PM
03/21/06 03:42 PM
Anonymous OP
Anonymous OP
I think it's a FestivaL...
It will take some work getting that surface level, but I'm sure it will come out nice with some elbow grease.
Re: paint job on a budget!? #22246
03/21/06 03:48 PM
03/21/06 03:48 PM
Anonymous OP
Anonymous OP
that's a civic
Re: paint job on a budget!? #22247
03/21/06 04:24 PM
03/21/06 04:24 PM
Anonymous OP
Anonymous OP
I'm more interested to see what happens when you pry all that "stuff" that looks to be glued on the car!
Re: paint job on a budget!? #22248
03/21/06 05:01 PM
03/21/06 05:01 PM
Anonymous OP
Anonymous OP
O..i already pried all those ornaments off total of 185...the glue was a bitch to take off so i went to pepboys and asked for their strongest glue/sticker remover and it DID the job. I;m using a sander, not a orbital one though its a square one, i'm using a 65Grit yea 65, i just started on the hood and boy o boy its taking forever!!! THe original owners painted this car with i dunno what but its tough. The cars original color is WHITE, they painted it RED and then the art work on top. But its coming off..to a point where i'm slowly see'ing metal on the hood, here are some pics.
Re: paint job on a budget!? #22249
03/21/06 05:47 PM
03/21/06 05:47 PM
Anonymous OP
Anonymous OP
A rotary sander with some heavy grit (80?) may be more of your friend getting the paint off. I'm sure it will be more aggressive than the square one you speak of (I'm assuming a palm sander).
I'm no expert, but I have stripped a bit of paint before...
