Re: Exhaust Interference and Drone Problems
[Re: 67autocross]
#2221477
12/27/16 01:50 AM
12/27/16 01:50 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
How about using a large flat bladed screwdriver or stock type lug wrench flat tapered end to push in between the header tube and steering box and used that to push it in a little I could try that. Maybe later in the week. I would fix the engine mount before you start bashing the header, if you have looked at other cars with the same headers and box you already know that you should have lots of clearance in that area. I guess that whoever put the engine in just bolted it in wherever it landed in the engine bay.... I actually read in another thread that someone else is having problems with the TTi shorties and Borgeson box. I'm curious if the '67-72 K-frame vs. 73+ K-frame makes a difference.
[Re: MuuMuu101]
#2221482
12/27/16 02:08 AM
12/27/16 02:08 AM
Posts: 10,948 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
The length of your tailpipe from muffler back matters a lot to the rpm where Drone is most severe. Just as a Church Organ makes different musical notes when different length pipes get air blown through them, so will your exhaust make annoying music.
Very roughly, if drone was severe at 2000 rpm, and much less at 1500 rpm, then your tailpipe length needs to increase 2000 divided by 1500 4/3 rds
Other things come into play here, such as the temperature of the exhaust gas, which will be higher the more the trottle is opened.
You could experiment to find the added length that snuffs out drone. Buy two ninety degree fittings, and two lengths of either solid or flexible corrigated pipe, and add maximum length for side outlet style exhaust, then cut off about two inches at a time untill the exhaust note suits you.
Drive up steep hills to demonstrate how a more open throttle changes exhaust temperature and therefore drone.
The quietest set up for low drone in the 1200 to 2200 rpm range is usually large "Helmhertz Trap" mufflers mounted cross ways near the rear bumper fed by as long as possible tailpipes. T-Traps of closed stub pipes the right length can also kill drone at a particular rpm. Really well stated. Furthermore, the tub of your unibody car is one big musical instrument as well. When the mufflers resonate, all that harmonic vibration will make the car itself drone. In fact, much of what you're hearing is the car! If you haven't gone the dynamat route this will help a bit but not completely. The last car that I installed dumps on was longer ago than I'd like to say. I found a great solution for the drone. I purchased a pair of Thrush resonators and installed them after my mufflers and added about a foot of pipe beyond them so the dumps dropped right in front of the rear axle and it completely solve my problem. Before I installed the resonators, the drone was unbearable like yours at a certain RPM. Second gear was a real beotch. Just remember that the harmonics of every exhaust system are different, so what worked for me may not work for you. If you want to see how harmonics work go inside a walking tunnel of decent length with smooth surfaces. Stand in the middle. Then start singing a low note and start raising the pitch. At some point your voice will begin to make the tunnel start ringing really loud! As of now, I have no sound deadening in the car. I wanted to lay some in the back for the electric fuel pump as that can get very noisy. But since the car is so stiff, the vibration is just circulating everywhere as it's trying to find something to give. 6th gear is unbeable between 65-80 mph (optimal CA cruising speeds). The magnitude of the drone is less at lower speeds. The problem is that the TTi system uses offset mufflers so I'm going to need my resonators behind the rear axle. There's plenty of room after the gas tank, but how much room after the resonators do you generally need before dumping the exhaust? Can you do it at the resonator outlet? A couple inches? I don't think I have enough room for a 12-18" resonator and another 12" of tubing. I would just dump directly out of the resonators. If you go over the axle you're achieving the same effect that 360view was referring to by adding pipe. No guarantees, but it's really the best you can do.
I’m listening.
[Re: Big Bad Bee]
#2221490
12/27/16 02:23 AM
12/27/16 02:23 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I would just dump directly out of the resonators. If you go over the axle you're achieving the same effect that 360view was referring to by adding pipe. No guarantees, but it's really the best you can do. I kind of like that idea.
[Re: Dave Hall]
#2221845
12/27/16 09:22 PM
12/27/16 09:22 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Headers are always a pain with fitment. TTI uses good tubing that is hard to dent. I was initially thinking that you could use a long pry bar in between the area there as well. If it's not transferring vibration into the column or making noise, I would just let it clearance itself. Plus you don't want to chance cracking the steering box while you are trying to dent the header.
A new iron curtain drawn across the 49th parallel
[Re: joes68340s]
#2222207
12/28/16 02:47 PM
12/28/16 02:47 PM
Posts: 75,112 A Banana Republic near you.
JohnRR
I ran a full TTI system in a 68 Barracuda the super turbos drone like crazy. I now have Ultra flows much better also tail pipes are a must. Same here with the short case super turbos on my big block Dart , I think it's the mufflers , the rest of my system is factory manifolds and mandrel bent tubes front to back.
[Re: MuuMuu101]
#2222216
12/28/16 03:00 PM
12/28/16 03:00 PM
JohnRR
Have you tried moving the engine to the passenger side some yet ?
I see you have a Borgensen box , TTi makes the headers to fit with a Chrysler box , is the Borgensen that much bigger in that area ?
Don't try to dent the header with a punch, that is not going to work, especially with the header on the engine and in the car.
If shifting the engine over doesn't get you some room I think you should just bite the bullet and pull the header out , dent it , and put it back.
As far as the drone it's those short case mufflers, put on an ultra flo and see if it changes it .
I have those TTi tailpipes, I'm still trying to figure out what the bleep was going thru TTi's mind when they came up with that mess. I cut mine all up to get them in the FACTORY location, total waste of money .
[Re: MuuMuu101]
#2408151
11/24/17 04:37 AM
11/24/17 04:37 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Bringing this thread back from the dead. I have to make this car more road trip/gf bearable. Gf loves the car, but it's pretty annoying that we have to raise our voice in the car to talk cruising around town. I haven't even taken her on the freeway, yet. Since the last post I had, the 14" Dynomax Super Flow mufflers were removed and 18" Magnaflow mufflers were placed in instead. This removed some of the drone, but not all. Now it only drones between 1800-2100 RPM, but is still pretty bad and in optimal cruising speeds. I also had the leaf springs moved in with Dr Diff's offset shackle kit so adding resonators to the tailpipes may be a no go at this point. I'll have to check tomorrow (finally, a day off). That being said, in December, I'm going to have a 3 week break from my master's program and the last week of the year, I'm taking off from work, so I'll have some time to work on the car. I am thinking about going with some advice most of you had in the beginning and getting rid of the turndown tailpipes and adding some clamp on exhaust tips to, hopefully, redirect the pulses away from the car instead of under the car. I can only imagine it should be pretty easy and only require grinding the tips off, deburring the tubes, and clamping new ones on. Once I have time to play with my el cheapo welder and be comfortable with it, I'll weld them in place in the future. I was thinking about either dual ( https://www.summitracing.com/int/parts/jex-jst123/overview/) or oval tips ( https://www.summitracing.com/int/parts/bor-20155/overview/), but am not sure which would look better. I want something a little different than classic round tips. Does anybody know if these usually come with clamps or if I should order some? If so, what's the best clamp to get? If this doesn't work, I may just follow 360view's advice and try clamping on 90's and making it sort of like a side exit exhaust from the back to get rid of that drone. I'm looking to order parts soon, so I can just have at it once I finally get my break. Any advice would be appreciated. Thank you all and Happy Thanksgiving!
[Re: MuuMuu101]
#2408189
11/24/17 12:06 PM
11/24/17 12:06 PM
Posts: 12,319 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I hope you can deal with your drone with the changes you are making. But my personal experience with this is that nothing will kill the drone other than some sort of after-axle resonator.
If you find an alternate fix, be sure to let us know.
Master, again and still
[Re: MuuMuu101]
#2408246
11/24/17 02:22 PM
11/24/17 02:22 PM
Posts: 671 Los Osos, Ca
CKessel
Los Osos, Ca
Running the exhaust out to the bumper will be a big help. I had turn downs in front of the diff on my Duster that got to be annoying with the sound resonance later on. Sounded cool at first but not later.
Carl Kessel
[Re: CKessel]
#2408297
11/24/17 04:04 PM
11/24/17 04:04 PM
dogdays
There's a big difference between running turndowns in front of the rear axle and running pipes out to the bumper. But if your tailpipes run to the back bumper and end in turndowns, changing the shape of the last 3" isn't going to change a thing.
One thing to think about is the floor is like a big speaker. You can reduce sound levels a lot by damping this area. There are many choices such as Dynamat, Fatmat, Lizardskin, and asphalt roofing material. I don't fancy my car smelling like the La Brea tar pits on a hot day, so the roofing material is out for me.
The trunk floor is another prime candidate. Then there is the hood and firewall. Lizardskin is applied by spraying so for the trunk and under hood areas it might be best. You may not want to be spraying in your car interior so one of the peel and stick products would be more readably utilized. Reading the websites I see there is more to the stuff than simple mass loading, which is what the asphalt roofing material does.
Here's an experiment for you: there are a lot of flooring products that come in one foot squares and are peel and stick. You cold run an experiment for just a few dollars. Apply the flooring material to your interior floor and trunk floor. See if it makes a difference. It won't cost a lot as I've bought squares at one of the dollar stores for a dollar a square foot.
I didn't read all the posts so I cant remember if you have an H or X pipe already. If you don't have one, get one in there.
The bullet resonators will also have a great effect on sound. Back in the day there was something called "chambered exhaust" Where the exhaust pipe was deformed so it acted like a muffler. I wonder if anyone has aomething like that to act as a resonator and not take up so much space.
Oh, and nice Dart! It looks super smooth and clean.
Good Luck, R.
Then there's sound cancelling technology.........
[Re: DaveRS23]
#2408347
11/24/17 06:16 PM
11/24/17 06:16 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
If you find an alternate fix, be sure to let us know. We'll see how it turns out. I have never been a huge fan of the turndowns so getting regular or dual exhaust tips will be a visual more pleasing to me and probably worth the investment. Again, I can add length to the back if I add a 90 degree bend an extend it to a "side exit" exhaust and if that doesn't work, then I'll have enough room for resonators.
[Re: dogdays]
#2408349
11/24/17 06:18 PM
11/24/17 06:18 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Good Luck, R.
Yeah, when I took my car to the shop last, I gave them some dynamat and told them to install it in the cabin and they never did so I still have some left over. For now, I just really don't want to start taking out the interior. Who knows, that may change once I have that week off.
[Re: MuuMuu101]
#2408378
11/24/17 07:58 PM
11/24/17 07:58 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Just walked to the garage and measured things out. Resonators are definitely not going on the tailpipes next to the leaf springs. There will be interference. With just tips alone, it seems like I will only extend the exhaust by 2 inches, so like some of you said, it may not do much. My other option is doing a rear-side exit exhaust which will definitely be interesting. Either I could just extend the exhaust to the side with a 45-90 degree bend capping it off with exhaust tips or I may have enough room to reroute the exhaust off with just a 60-90 degree bend and a resonator (Either Jones Exhaust - https://www.summitracing.com/int/parts/jex-jr25/overview/ or Vibrant Performance https://www.summitracing.com/int/parts/vpe-1792/overview/). If I go to the resonator route, I will probably just have the "cannon" look as I won't have enough room for exhaust tips. Not sure how that will change the sound but hopefully it eliminates drone. What exhaust clamps do you recommend? I take it these are for pipe-to-mufflers/resonators ( https://www.summitracing.com/int/parts/pye-hvc10/overview/) and these are for pipe-to-pipe ( https://www.summitracing.com/int/parts/pye-hvc65/overview/).
