Re: Article on Muscle Motors new block
[Re: jim sciortino]
#2219498
12/23/16 11:44 AM
12/23/16 11:44 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Hopefully, everything works out and this becomes a deal that MOPAR guys are in dire need of, but I have one question....
With a 4.800 bore center, how can a block at 4.500 have over .400 at it's narrowest point - the area adjacent to the hemi-specific exhaust pushrod clearance scallop......as stated in one of the picture captions??? Wouldn't the narrowest point be between the cylinders at 4.500??? Yeah, that's exactly what I was curious about.
[Re: MR_P_BODY]
#2219557
12/23/16 01:15 PM
12/23/16 01:15 PM
Posts: 2,072 Apollo, PA.
B1MAXX
Apollo, PA.
I wonder why they didnt go ahead and drill the cross bolts on #5 specially since its prepped for it.. but at least there is a STRONG block for the BB guys... my mega block with 4.5 bores only had .200 walls at the thinnest point.. whats the next ring size over a 4.5.. does chevy have a 4.6 ring 4.6 is a common BBC size. The biggest bore I have seen for a 4.84 bore space was 4.605. I believe that the Dart block can go 4.625 at 4.84 bore space.
[Re: AndyF]
#2219597
12/23/16 01:52 PM
12/23/16 01:52 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I wish Mike at MM the best of luck with this venture.
Lord knows the BB guys sure could benefit from having these things available.
If the quality is consistantly decent, and they prove they can be delivered in a timely fashion, I expect they'll sell tons of them.
[Re: AndyF]
#2219623
12/23/16 02:20 PM
12/23/16 02:20 PM
Posts: 4,219 New York
polyspheric
New York
I think .400" is on the thrust surfaces, not between adjacent bores.
Boffin Emeritus
[Re: AndyF]
#2219754
12/23/16 06:35 PM
12/23/16 06:35 PM
Posts: 4,335 Morrow, OH
markz528
Morrow, OH
They called me today to give me an update. I've got one of the first 10 that they cast. Its coming along..............
[Re: markz528]
#2219761
12/23/16 06:54 PM
12/23/16 06:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
They called me today to give me an update. I've got one of the first 10 that they cast. Its coming along.............. So when is your date for pick up/ or ETA and when did you put you order in.. thanks... and what did you order
[Re: AndyF]
#2219781
12/23/16 07:14 PM
12/23/16 07:14 PM
fast68plymouth
So. Burlington, Vt.
Hopefully they can be able to continually have them going through the process.
I'm sure the BB Mopar crowd will be timid about laying down big deposits initially, which means the cash flow for MM may be a bit tough in the early going of this endeavor...... But I think in the end it will be a case of "if you build it, they will come".
[Re: MR_P_BODY]
#2219787
12/23/16 07:27 PM
12/23/16 07:27 PM
markz528
Morrow, OH
They called me today to give me an update. I've got one of the first 10 that they cast. Its coming along.............. So when is your date for pick up/ or ETA and when did you put you order in.. thanks... and what did you order I ordered it in July with the understanding that I would get it in the spring. Honestly I probably won't need it till at least summer. I ordered it as a rotating short block. It is a RB and will be a 512 cubic inch with Molnar crank and rods. This is a street/strip build with target of 650 hp. Its getting a set of Todd Marsh side winder heads. Pretty tame build. The first motor of the 10 is machined and assembled. Getting ready to hit the dyno - they want to verify all is good before machining the rest of them. At this time getting the motor in the spring is probably realistic based on current info.
[Re: 500ci barracuda]
#2220140
12/24/16 02:13 PM
12/24/16 02:13 PM
BradH
Nice block. I am looking for a new block to build a 600ci. Anyone know the cost of this block. Mark The linked article contains a list of options available and their associated costs above & beyond the $3800 base price.
[Re: AndyF]
#2220267
12/24/16 04:52 PM
12/24/16 04:52 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
I know some serious bracket guys that want cast iron blocks due to being more consistent by holding heat but other than that if a cast iron block is $5000 why wouldn't you spend another $1000 and get an aluminum block. Not being critical at all just curious what people's opinions are.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: MR_P_BODY]
#2220299
12/24/16 05:46 PM
12/24/16 05:46 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
I wonder why they didnt go ahead and drill the cross bolts on #5 specially since its prepped for it.. but at least there is a STRONG block for the BB guys... my mega block with 4.5 bores only had .200 walls at the thinnest point.. whats the next ring size over a 4.5.. does chevy have a 4.6 ring 4.600 and 4.625 are common sizes for BBC 565 cu in strokers in 9.8 deck Dart Big M blocks....lots of rings available....I'm learning it all for S/C and S/P racing....it's like learnig to speak all over again.
[Re: Chassisman]
#2220337
12/24/16 06:44 PM
12/24/16 06:44 PM
Superfreak
Superfreak
I wonder why they didnt go ahead and drill the cross bolts on #5 specially since its prepped for it.. but at least there is a STRONG block for the BB guys... my mega block with 4.5 bores only had .200 walls at the thinnest point.. whats the next ring size over a 4.5.. does chevy have a 4.6 ring 4.600 and 4.625 are common sizes for BBC 565 cu in strokers in 9.8 deck Dart Big M blocks....lots of rings available....I'm learning it all for S/C and S/P racing....it's like learnig to speak all over again. Also in the 10.2 deck heights.
