Re: My New Best - Brazil
[Re: markz528]
#2219483
12/23/16 10:44 AM
12/23/16 10:44 AM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
Curious where the track is. I know its not close to you, but I believe there is a track in Curitiba. I go to that area several times a year and always wanted to go to an event but has not yet worked out. Hi Mark, This track is in Nova Santa Rita - RS. www.velopark.com.br Curitiba has AIC, but unfortunatly we don't have many events there. Last year AIC almost closed. When you will go to Curitiba, please send me a message that I can go there also.
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
[Re: 360tripleblack77]
#2219791
12/23/16 07:34 PM
12/23/16 07:34 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Curious where the track is. I know its not close to you, but I believe there is a track in Curitiba. I go to that area several times a year and always wanted to go to an event but has not yet worked out. Hi Mark, This track is in Nova Santa Rita - RS. www.velopark.com.br Curitiba has AIC, but unfortunatly we don't have many events there. Last year AIC almost closed. When you will go to Curitiba, please send me a message that I can go there also. I have no plans at this time, but I will be there a few times next year. Was there twice this year (should of been 3 times but got someone to go for me). Was there 4 times last year. I actually go to Jaragua do Sul in Santa Catarina which is about 2 hours from Curitiba. I will definitely send you a note when I have plans to be there!
#2219873
12/23/16 10:23 PM
12/23/16 10:23 PM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
I went with the Cal trac system years back and upgraded to vikings and sliders.If you choose to go with sliders it will lower the rear a tad. Looks like your blowing the rear tires off in the vid.
My New Best - Brazil (Updated)
#2420220
12/18/17 08:23 AM
12/18/17 08:23 AM
360tripleblack77
Yeah, finally My Dodge is back to the track and as I said in another topic I was changing from Super Victor to Tunnel Ram Setup and some changes on suspension to reduce bouncing on the start. My best ET so far was 1.58 / 4.50 / 6.98@100.06 I ran only 3 times on the weekend. because the day was very hot. The track temperature reached 162 degrees and after we almost fry, rain! Special thanks for humpty for all advices to adjust suspension and Dominic Thumper for advices to fine tunne on Tunnel Ram setup. I'm still working... lol... next step is change to sliders and mono leaf.
Re: My New Best - Brazil - << UPDATED >>
[Re: Jeremiah]
#2421176
12/19/17 10:33 PM
12/19/17 10:33 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I'm looking at the weight of the car. And the mph.. thing is making big Power.. I just love that body style I wish I could get my hands on one.. I watched your video I so wanted to see roll on that Camaro...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2421335
12/20/17 07:45 AM
12/20/17 07:45 AM
360tripleblack77
Thank you Shiloh, your compliments means alot because your car is like an inspiration for me. She still fat but I'm starting work in some weight reduction nothing so radical but I hope reduce around 100lbs. Engine loved Tunnel Ram and I could feel big difference mainly on throttle response. I was running little lean and I think that I can run on 6.6s just correcting that. Camaro is owned of a great friend, his name is Diego also. lol. He ran his best in 6.4s this weekend. Basically we have same weight, his engine is bigger than mine (SBC 427 vs SBM 360) and make more power than me mainly because he had great AFR heads vs My Edelbrock RPMs. He is a great friend and tough competitor. Next step is finally change from OEM leaf springs to Calvert Monoleafs, install sliders and build a 8 point roll bar to have a better chassis stiffness. By the way, if you want a Brazilian Dodge Charger R/T please let me know.
[Re: dart_73_br]
#2421426
12/20/17 01:39 PM
12/20/17 01:39 PM
360tripleblack77
Thank you Fernando... Good to see you are here at Moparts also.
Re: My New Best - Brazil - << UPDATED 2021 >>
#2968003
09/27/21 09:30 PM
09/27/21 09:30 PM
360tripleblack77
Hello Guys!!!
Last updates at my car worked very well. Installed a 8 point roll cage, monoleafs, sliders and slant 6 torsion bars. No changes at the Engine so far.
I still fighting against weight transfer but the car launch much better. I will try to get a video to share here.
