Re: '68 383 Dart Engine Paint Question
[Re: Rhinodart]
#2220793
12/25/16 07:05 PM
12/25/16 07:05 PM
Posts: 17,529 Las Vegas, NV
6bblgt
Las Vegas, NV
pay attention Jim 1968 fender tag is on driver's inner fender emission decal is on passenger inner fender or am I missing something?
[Re: 6bblgt]
#2221151
12/26/16 03:40 PM
12/26/16 03:40 PM
Posts: 43,650 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
pay attention Jim 1968 fender tag is on driver's inner fender emission decal is on passenger inner fender or am I missing something? Still don't agree with the emission decal on the passenger inner fender on Hamtramck cars. My post above was that I have seen PLENTY of 68 Dart's with the fender tag screwed on looking AWAY from the fender, turned 180 degrees from normal...
JB Rhinehart, Realist
A-Body's RULE!
[Re: njmopar]
#2221918
12/27/16 11:40 PM
12/27/16 11:40 PM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
We had a nice near 60F day today so I got the engine painted. I couldnt stand not having paint in all areas, so I took off the water pump housing and damper, painted, then reinstalled. Here are some pics. These are just temporary valve covers, not my fresh rechromed ones. This is Bill Hirsch engine paint First time using, came recommended. I must say, has to be the nicest engine paint I ever used. Flows on so nice. Drys very quick. Since it comes in quarts, you can brush it on in spots, like I did for the water pump housing bolts and the seam. The only gotcha moment was later on when I was test fitting some parts, as I was so pumped to see things fitted. I took out the choke well cup and what the???, doesnt fit. For some reason I bought this thinking it was like my 71 440, which I guess this cup didnt come until 1970. So does the choke just sit in the well, no gasket or anything?
Before pump housing and damper is on.rearAll parts onother side
[Re: njmopar]
#2222276
12/28/16 05:03 PM
12/28/16 05:03 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
What paint did you use ? that doesn't look like the right color ?
oh and FYI , exh manifolds installed when engine was painted and painted engine color .
Re: '68 383 Dart Engine Paint Question - Now Painted -
[Re: njmopar]
#2222295
12/28/16 05:40 PM
12/28/16 05:40 PM
njmopar
Clinton, NJ
The flash on my phone is playing with the color, depending on how it hits it. It is turquoise. As mentioned I used Bill Hirsch paint I know about the manifolds, rather get those jet coated then let the paint burn off.
