Window Net Install #221692
02/11/09 09:50 PM
02/11/09 09:50 PM
NC
chris3 Offline OP
chris3  Offline OP
NC
Any one have photos of window net installed on a slant bar roll cage? Got to install one in a duster.
Re: Window Net Install [Re: chris3] #221693
02/11/09 10:18 PM
02/11/09 10:18 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Don't know if you can see it right or not, but here is mine.
Re: Window Net Install [Re: 70HemiGTX] #221694
02/11/09 10:19 PM
02/11/09 10:19 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Here's a differnet one.
Re: Window Net Install [Re: 70HemiGTX] #221695
02/11/09 10:31 PM
02/11/09 10:31 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Remember to weld all the attaching points to the inside part of the cage.
I still need to redo mine
Re: Window Net Install [Re: 70HemiGTX] #221696
02/12/09 12:05 AM
02/12/09 12:05 AM
NC
chris3 Offline OP
chris3  Offline OP
NC
This quick and useful response is why this site is so valuble. Thanks guys. Any more?
Re: Window Net Install [Re: chris3] #221697
02/12/09 07:38 AM
02/12/09 07:38 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Here's a couple for you. You can see a tab in the back just below the cross bar and another tab on the down bar.
Here's a pic with the net. When unbuckled at the top it sort of hinges down out of the way.
I have a clevis pin with a R clip I use at the top so I can drop it down out of the way easily for trips out for ice cream
Re: Window Net Install [Re: Bigcube] #221698
02/12/09 09:22 AM
02/12/09 09:22 AM
NC
chris3 Offline OP
chris3  Offline OP
NC
BIGCUBE:
This is the idea I had. How do you have the rod (L-shape) at the bottom of the net attached? Does this rod swing in to the inside when you un-buckle at the top?
Thanks I'm getting some good ideas. Got to get this in before Pinks at Charlotte.
Re: Window Net Install [Re: chris3] #221699
02/12/09 09:32 AM
02/12/09 09:32 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
One end under the cross bar is bolted so it will hinge down. At the front there is a threaded stud with a washer and nut on the bottom side. The front end of the L will slide down through the bracket, it will pull up until the washer hits the under side of bracket.
