Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc.
[Re: captainjerky]
#2243313
01/29/17 11:41 AM
01/29/17 11:41 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Nice Project, very clean!
Building a car with a Toddler is no joke lol. Lots of late nights and work during nap time! Thanks! Yes, building with a toddler has some added challenge! Goody, you have no idea how much I appreciate your build thread. You've done almost exactly what I've been planning, though I plan to paint in Limelight or similar and use something like these rims: http://www.etmags.com/lt_iii.htmlbecause I loved the race AAR Cudas and these are basically Minilites in 17" size. Seriously, your build looks just like my Word document where I've been storing up every tidbit of info I can find. It's daunting to know there are so many things to do, but at the same time I love the fact that every car like this is going to be a unique expression of driver and builder. I'm looking forward to keeping an eye on your thread! Thanks, Ryan Thanks Ryan, it's been quite a bit of work, hopefully I can get over the electrical hurdle here soon. I knew the wiring was going to be a lot, but it is more time consuming than I expected to get everything done "right" and routed well. There is definitely nothing "cookie cutter" about this car, it'll be all that I wanted.
[Re: GoodysGotaCuda]
#2248435
02/06/17 12:34 PM
02/06/17 12:34 PM
Posts: 10,157 MN
JERICOGTX
MN
Coming along nicely Goody!
69 GTX
68 Road Runner
#2261231
02/28/17 06:54 PM
02/28/17 06:54 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Your build is similar to mine but on [/size]Steroids. [size:11pt] I too had my car for a long time (25 years but you are younger than me), ran the socks off of it and then started a rebuild. I did not do a hemi, I wish I had. Put in a used 5.2L married to a lockup A904. The other thing different, I added my toddle after it was done. But all the wiring, upholstery, dash rebuild, engine swap, transmission rebuild, etc. was done in my two car garage in a covenant controlled townhouse. Wish I has seen your body flip trick. I have seen your posts on other boards and I know your electronics aptitude is high. That was my background. Never rebuilt a transmission before but had torn down a lot of engines. I admire your shop and engineering skills. I dumped the Tanks, Inc tank because of leak issues, most of them my fault. Just got tired of draining the tank then dropping it 4 times just to get the leaks to stop. I went with Spectra and have had no leaks and if there is one, remove the left rear tire and there is all the plumbing. I am running Megasquirt 2 and if I ever run a hemi, it will be a Megasquirt 3. The project on my desk now is a PWM closed loop regulator circuit to eliminate my mechanical regulator. I went with Vintage Airs bracket for the 318 and put a Sanden R12 (read early Mustang) scroll compressor on. I had to electronically control the clutch as it was getting so cold, it was freezing up on 90 degree days. All of the plumbing is the stock stuff it came with but I crimped new hoses on the old fittings. I used barrier stuff so if I do have to go to 134, I can. Good luck on the build. BTW, you can get a car seat to work in the back seat. Have to add a bracket to tie the top of the seat strap to the frame. My toddle loves it.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#2262370
03/02/17 10:09 PM
03/02/17 10:09 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Your build is similar to mine but on [/size]Steroids. [size:11pt] I too had my car for a long time (25 years but you are younger than me), ran the socks off of it and then started a rebuild. I did not do a hemi, I wish I had. Put in a used 5.2L married to a lockup A904. The other thing different, I added my toddle after it was done. But all the wiring, upholstery, dash rebuild, engine swap, transmission rebuild, etc. was done in my two car garage in a covenant controlled townhouse. Wish I has seen your body flip trick. I have seen your posts on other boards and I know your electronics aptitude is high. That was my background. Never rebuilt a transmission before but had torn down a lot of engines. I admire your shop and engineering skills. I dumped the Tanks, Inc tank because of leak issues, most of them my fault. Just got tired of draining the tank then dropping it 4 times just to get the leaks to stop. I went with Spectra and have had no leaks and if there is one, remove the left rear tire and there is all the plumbing. I am running Megasquirt 2 and if I ever run a hemi, it will be a Megasquirt 3. The project on my desk now is a PWM closed loop regulator circuit to eliminate my mechanical regulator. I went with Vintage Airs bracket for the 318 and put a Sanden R12 (read early Mustang) scroll compressor on. I had to electronically control the clutch as it was getting so cold, it was freezing up on 90 degree days. All of the plumbing is the stock stuff it came with but I crimped new hoses on the old fittings. I used barrier stuff so if I do have to go to 134, I can. Good luck on the build. BTW, you can get a car seat to work in the back seat. Have to add a bracket to tie the top of the seat strap to the frame. My toddle loves it. Thanks for the input! Where did you have issues with the Tanks Inc setup? I have a bench test PWM setup that would easily drive a fuel pump or fan using a Ford FPDM. I used an Arduino to generate the PWM signal. I am not sure I will actually implement it on anything, for now I want the car back on the road with minimal fuss or distractions! https://www.youtube.com/watch?v=R7-KgCiqUbQ
#2270009
03/15/17 02:19 PM
03/15/17 02:19 PM
Posts: 288 Georgia
scf100
Georgia
LOOKS GREAT.....How did the AMD front header panel fit?
1970 Challenger R/T convertible 383 4-speed Triple Black
[Re: scf100]
#2270258
03/15/17 09:46 PM
03/15/17 09:46 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
LOOKS GREAT.....How did the AMD front header panel fit? I can't speak for that specifically, the body shop handled all panel alignment, however, I did not hear any complaints about it. The AMD trunk lid was warped like a Lays potato chip.
[Re: FrankenScamp]
#2295806
04/28/17 09:18 PM
04/28/17 09:18 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Jones'n for an update here Goody. Sorry, I do not have much [unfortunately]. I have the fuel pump fitted within the tank and have managed to get the battery tray mounted up [trunk]. I have the all of the parts on-hand for the fuel system with new injectors, nylon braided fuel lines, LT1 regulator and aeromotive fuel rail. The cooling fans came in last week, I'll acquire some factory-line connectors in order to get them wired up [V6 Ford Contour Fans]. I've been bogged down studying for my PMP exam and running around for Easter family festivities. Hopefully I can get it fire up before our Italy trip in June I used a marine style fuel sending unit for this application as it does not have an extended lever arm. My previous gauge cluster [autometer] was very sensitive to fuel slosh and it tried to achieve an accurate reading, which means the fuel gauge swayed a lot. With this marine style, the sending unit float travels within a shielded tube with openings in the bottom and top, it should provide a very stable fuel reading, in comparison.
#2295907
04/29/17 01:01 AM
04/29/17 01:01 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Goody do you have the rubber boots for those heim joints? Seals it RERS3. You need 10 for the Hotchkis kit It helps to have them for longevity
